I have installed the Navisworks 2014 and cannot figure out how to make the Switchback work for the Revit 2013 file that I am using. Any suggestions or ideas on how to get this command to work?
If you have not installed the Navisworks Export Utility, you can download and install from the page below:
http://www.autodesk.com/products/autodesk-navisworks-family/autodesk-navisworks-nwc-export-utility
I would then make sure to enable switchback for 2014 with Revit by going to the Add-ins tab > Navisworks Switchback 2014.
