Dear All,
We also have a same concern as we are a Ingr Client also using Design Review and also using Naisworks on Large scale for PDS users. We will have big problem in near future when we completely switch our execution from PDS to SP3D.
Do we have any updates on this as last message was posted on 11-09-2009. Its almost one year and no solution.
Messag for Navisworks development Team
1. While we generate vue files from SP3D. It also creates Xml file containing the label/annotation data which is being used along with vue. If requied we can provide xml file to investigate the team to explore it and make it compatible xml which can be readily import in to Naviswoks.
2. For Model Graphic, Since Dgn is acceptable format for Navisworks & in SP3D, facility is available to export the Model data into Dgn format. So development team just need to link this graphic along with the compatible xml file.
3. Alternate solution is, Both big banners seat together and decide about common format which can be exchangable to both the review packages, which we think is tricky process but at some point of time, we hope it will be possible. Look at the simplest example of Frameworks & Tekla Products for structure modellilng. Now this is possible two way through SAT format because of their great efforts and made our life comfortable. Same way, we expect both AutoDesk and Ingr works together to find the solution.
A converter available @ unitec.de
Refer link below
http://www.youtube.com/watch?feature=player_embedded&v=dAL2PpR7IRg
Unitec bietet Ihnen nach dem Baukastenprinzip erweiterbare 3D CAD-
Reader für Navisworks an. Nach dem Einlesen stehen Ihnen abhängig
von den Lizenzen die Funktionen von Navisworks zur Verfügung.
Dazu gehören z.B.:
· Smartplant 3D Erweiterung
· 3D PDF Erweiterung
Dear AutoDesk,
we are facing the same challenging. Is there any update about the support of Intergraph uve format? We are also the Intergraph SPF user which has 3D model in the file format zvf. Can naviswork suppor this format?
Luming
Another possible workaround, at least for Tekla and other software is the IFC file format.
Perhaps the combination of an IFC export in SP3D and the XML file with the object data from SP3D could also be a (better) way then the DGN route, as SP3D is only capable of exporting to the old and very limited MicroStation J DGN file format.
Dear All,
Atlast, i made the tool to generate the S3D model into Navisworks (with property info).
To generate the current NWD file, it took more than ~ 2hours. Currently working to improve the performance.
Raghu
Perfect! Well done!
Do you have a plan to share your program with other people for solving this problem?
Regards
