Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
FURTHER DEVELOPMENTS - SP3D .vue FILES
13 REPLIES 13
Message 1 of 14
tasliou
9093 Views, 13 Replies
Dear Autodesk
I am a client of Intergraph and User of Smart Plant Review. However i had the oportunity also to work with Navisworks and have discovered that the functions of NavisWorks could boost significantly the productivity of my work but so far Navisworks does not support files generated by SP3D.
Is Autodesk going to integrate models of .vue file formats from SmartPlant 3D of Intergraph sometime in the near future?
or should i renew my licences of the Smart Plant Review?
Best Regards
13 REPLIES 13
Message 2 of 14
richardparker
in reply to: tasliou
Hello tasliou
The Navisworks team are always keen to broaden the range of file formats that we support and .vue / SP3D is #1 on our priority list at the moment. However when working with non-Autodesk proprietary file formats we typically have the support or cooperation of the format owner (or a suitable 'open' format exists). When neither of those are available it can be an extremely tricky task! We are continuing to investigate options that could allow us to deliver interoperability between SP3D & Navisworks.
Often 'customer power' is key to encouraging an organization to 'open up' their proprietary formats and support multi-product workflows - we would certainly recomend that you take this approach with other software vendors that you purchase from!
Best Regards,
Richard
Message 3 of 14
tasliou
Dear Richard,
Thank you for your FeedBack.
As you suggest, i will address officialy to Intergarph my concerns.
However it is realy a disapointment to have the 2 main 3D Design review developers not to be able to cooperate for the common benefit of both companies.
My Best Regards
Message 4 of 14
samv74
Dear All,
We also have a  same concern as we are a Ingr Client also using Design Review and also using Naisworks on Large scale for PDS users. We will have big problem in near future when we completely switch our execution from PDS to SP3D.
Do we have any updates on this as last message was posted on 11-09-2009. Its almost one year and no solution.
Messag for Navisworks development Team
1. While we generate vue files from SP3D. It also creates Xml file containing the label/annotation data which is being used along with vue. If requied we can provide xml file to investigate the team to explore it and make it compatible xml which can be readily import in to Naviswoks.
2. For Model Graphic, Since Dgn is acceptable format for Navisworks & in SP3D, facility is available to export the Model data into Dgn format. So development team just need to link this graphic along with the compatible xml file.
3. Alternate solution is, Both big banners seat together and decide about common format which can be exchangable to both the review packages, which we think is tricky process but at some point of time, we hope it will be possible. Look at the simplest example of Frameworks & Tekla Products for structure modellilng. Now this is possible two way through SAT format because of their great efforts and made our life comfortable. Same way, we expect both AutoDesk and Ingr works together to find the solution.
Message 5 of 14
vsahayaraj
A converter available @ unitec.de
Refer link below
http://www.youtube.com/watch?feature=player_embedded&v=dAL2PpR7IRg
SmartPlant 3D Interface für Autodesk Navisworks
Unitec bietet Ihnen nach dem Baukastenprinzip erweiterbare 3D CAD-
Reader für Navisworks an. Nach dem Einlesen stehen Ihnen abhängig
von den Lizenzen die Funktionen von Navisworks zur Verfügung.
Dazu gehören z.B.:
· Smartplant 3D Erweiterung
· 3D PDF Erweiterung
Message 6 of 14
lum.wang
in reply to: samv74
Dear AutoDesk,
we are facing the same challenging. Is there any update about the support of Intergraph uve format? We are also the Intergraph SPF user which has 3D model in the file format zvf. Can naviswork suppor this format?
Luming
Message 7 of 14
Patrick_Aps_9121
in reply to: lum.wang
Another possible workaround, at least for Tekla and other software is the IFC file format.
Perhaps the combination of an IFC export in SP3D and the XML file with the object data from SP3D could also be a (better) way then the DGN route, as SP3D is only capable of exporting to the old and very limited MicroStation J DGN file format.
Message 8 of 14
Jganjei
in reply to: Patrick_Aps_9121
Hi Everybody;
Any update on this topic after 6 years !?
Tnx
Message 9 of 14
Patrick_Aps_9121
in reply to: Jganjei
Support for SP3D has not made the 2006 release, but Autodesk is working on it. Maybe next year, maybe not. The trouble is that the .vue file format is proprietary and Intergraph is not keen on sharing file formats at all.
Message 10 of 14
Dear All,
Atlast, i made the tool to generate the S3D model into Navisworks (with property info).
To generate the current NWD file, it took more than ~ 2hours. Currently working to improve the performance.
Raghu
Message 11 of 14
Perfect! Well done!
Do you have a plan to share your program with other people for solving this problem?
Regards
Message 12 of 14
aysennikov
Interested as well
Message 13 of 14
Can you share  what software used to convert SP3D data into NWD
Message 14 of 14
No he cannot. And this is obvious.
Rail Community
