Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Diagonal lines between walls and doors
2 REPLIES 2
656 Views, 2 Replies
I am trying to render a scene using sketch/hidden settings in NW Simulate 2013. I am getting diagonal lines on the surface of the wall, from the corner of a door to the corner of the wall (see attached image). The original model is a .dwg import using walls and doors drawn in AutoCAD MEP 2013.
Any ideas as to why this is happening?
Many thanks
Mark
2 REPLIES 2
Lance.Coffey
To see if this issue is related to the DWG file, you could try creating a new DWG, draw a similar wall, and door, bring into Navisworks, and see if the same issue occurs.
If the issue does not show up, then you can compare the differences between the original file and the new one.
If the same issue occurs, it would be useful if you could attach the new (hopefully small) files, and include a description of the steps you are going through, so that we could try to reproduce what you are seeing.
Lance Coffey
Technical Support Specialist
in reply to: Lance.Coffey
Hi Lance,
I have solved this by creating a new DWG from a template Aecb Model (UK Stb) and copy-pasting the walls into that new DWG.
Not sure as to what went wrong with the original file. I have compared the two but can't find any discernible differences.
I have attached the files to see if you can spot any differences (should you wish to do so).
Many thanks for your assistance.
Mark
Rail Community
