I need your expertise.
I have an IFC I need to open in Revit. However, when it complete, warninig list appears stating some geometries could not be converted.
Since Revit cannot find "missing" geometries, I am wondering if there are ways to use Navis to compare original IFC data and Revit data generated from IFC.
I found Revit data has "Tag" parameter under type tab that is identical to IFC's "Tag" parameter.
(I also found Revit's "IfcGUID" parameter under element tab, is same as "GLOBALID" in IFC.)
I thought, if I can compare both parameters and search for the difference, I can pin point which instance is missing in Revit.
Please advice.
Of course, if there is a better way to do so, I would like to hear those ideas.
Regads,
Jun
Jun Nagase / 長瀬 純
BIM Manager
Nikken Sekkei Ltd.
Thank you very much for the advice.
I will try as soon as IT guys install the exporter...
Thank you very much
Regards
Jun Nagase / 長瀬 純
BIM Manager
Nikken Sekkei Ltd.
