Hello all,
I have run into 3 problems when bringing AutoCAD dwg files into Navisworks, and was wondering if anyone has a solution to any of these.
1. I have 2 swept surfaces that were originally created with Inventor 2014. The Inventor ipt file appears intact in Navisworks (Manage 2014), but if I export a dwg file (in order to include additional geometry created in AutoCAD) and read this into Navisworks, the surfaces show up bulged/distorted.
The exported dwg file from Inventor has no issues when opened in AutoCAD (Surface_sweep_dwg.jpg). The distorted result in Navisworks can be seen in Surface_sweep_nwc.jpg
2. AutoCAD hatches do not show in Navisworks. I have read this has been a known problem for quite some time - has it still not been resolved?
3. AutoCAD blocks with attributes - attributes do not show in Navisworks.
Thanks in advance,
Samu
Hi Patrick,
Thank you so much for the reply. Changing this:
"setting the Faceting Factor to a higher number , like 10 instead of 1"
gave me the result I was looking for!
Thanks again,
Samu
