I have a site model (really just a flat plane with sections defined for the site demo) that I created in Sketchup and imported into Navisworks 2013. For whatever reason I cannot seem to override the color or transpacency of the plane, and even if I go back to Navisworks and change the colors and re-import it still comes in as a giant white sheet. Any suggestions? I really need to show each demo section as a slightly different shade of one color.
Solved by dgorsman. Go to Solution.
Are you using the full-rendered mode? This will use the assigned materials and lighting values, which override any of your color and transparency overrides.
