Hi.
I download for trial NavisWorks Manage 2011, to follow one of the examples require to import a project but I get the following error, anyone knows why this happens?
Hi jmcruzr,
Hello. I see you are running into an error loading an MS Project file. It is hard to say exactly what is causing the issue you are experiencing, but there are some things you can check on:
First, your post mentions you are using an MS Project file.
-The Version of the file you are trying to load, Navisworks can utilize 2003, 2007 and MPX MS Project files. I would resave your model from Project and make sure it is in one of these formats.
-Build a basic project file with only one or two fields. If you can link to a small project file, this error may point to data errors in your project file.
This may not be an MS Project file. The screenshot of the error seems to point to Primavera being the source of the issue. Are you certain the file is from MS project?
-If you are trying to link to a Primavera database, you need to make sure you have the proper Primavera components installed and you need to be using a user account with full administrative privileges to Primavera.
-If you are using a Primavera exported file, which I am thinking you may be, there is likely a field in the file that is populated with a NULL value, incorrectly. You will want to have your Database administrator check your data table for NULL issues.
Thank you for participating in our community!
David Dembkoski, Autodesk Product Support
Thank you for your question.
Does the error pop up when you right click on the link tab?
The error usually indicates that plugin can't be found. Firstly, I suggest you to install the product again. If the problem is not fixed, please check if there is "NWTLPrimaveraPM.dll" under your installation folder(e.g. C:\Program Files\Autodesk\Navisworks Manage 2011). If it exists, please use "Regsvr32 " command to register NWTLPrimaveraPM.dll. Then run your Navisworks again.
Hope this will resolve your problem. Otherwise we may need more information to help you out of the trouble.
thanks,
-Reed
You may use next software which can help you in this complicated situation. The program has different possibilities such as working under any Windows OS, system requirements. microsoft project recovery solve out almost every trouble with ms project files.
