Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Can URL links associated with Revit components become hyperlinks in Navisworks?
5 REPLIES 5
nelsonweeks
2679 Views, 5 Replies
My testing suggests no, but I am hoping I missed something.  I am able to copy the url information and create a link, but I am hoping for automation.
5 REPLIES 5
I have no experience with Revit, but I know that when an URL is in a DWG, it remains in the published DWF.
and I know that NavisWorks Freedom can open DWF.
So maybe you can publish to DWF from Revit,
and open the DWF in NavisWorks Simulate and see if you have URLs.
But it's just a hunch....
dembkod
in reply to: nelsonweeks
Hello nelsonweeks,
Users have imported URL links as properties, but the links themselves will not be active links. That is, you will not be able to click on them and navigate directly. The links would be text-based.
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
in reply to: dembkod
I also have a question about this. In the current version converting URL's is partially possible. If you create a Revit parameter of type URL, and in the export settings you choose 'convert URLs', then the URL properties that are type-parameters, come as an active link in Navisworks. But I have 2 questions about this:
1: Why does the conversion of URL's only work on Type-parameters and not on Instance-parameters?
2: Why are all the names of the links 'Revit' instead of the parametername?
BalajiHTI
I also have the same issue and same questions as listed as 1 & 2 in your post. Its funny its been five years and Navisworks Manage 2016 has the same behavior. On the other hand, if I upload the Revit File to Autodesk 360 Drive, I can access URLs in Instance Parameters. URLs like websites, phone numbers and email addresses. I can think of a lot of use cases for these functionalities. Would be too cool if it is possible if the URLs can refer also to another A360 File! I would raise an Idea in the respective forums for sure. 🙂
You can use the plugin "Properties+" in Navisworks.
Rail Community
