Hi,I'm new in navisworks,now we want to make winform control application(not plugin),the customer wants to have the same function like clash,timeliner,sectionplane and other functions.I have a question,is the current version of api can do these things?can i make a application just like a "little navisworks"? or the current version is better for plugin? TKS!!!!!
Solved by xiaodong_liang. Go to Solution.
as I replied you through ADN, the .NET control app of current releases cannot access .NET plugin. So Timeliner or Clash is not available. But section plane is the built-in ability of COM API. you should be able to access it in .NET control.
Hello,Mr.Liang
so am i able to understand it as it's better to create plugins than control application?it's hard to create such winform application.
by the way,the sectionplane function(the demo in blog) is difficult to understand and i think it's difficult or can't reach the effect like navisworks(UI),right?
yes, better to use plugin.
but, if you just want to know the information of TimeLiner/Clash of a document, you could consider to write an Automation behind your control app. i.e. The control app calls the Automation EXE. The EXE starts Navisworks (can be invisible) calls a plugin which accesses the TimeLiner/Clash info and writes them to a text file. Finally your control app reads the text file and displays the info in your own interface such as a grid for TimeLiner Tasks.
As to sectioning API, I'd suggest you take a look at the ability of UI firstly, understand how it works with the 6 planes. Thus you may have an idea how to understand the API code. In addition, I'd suggest you just try the code, instead of guess. Of course, if you find any problems, please shout.
