Navisworks API
Message 1 of 4 (195 Views)
What data read by Naviswork
195 Views, 3 Replies
01-18-2013 12:08 AM
Hi All,
I want to add custom data to an entity in AutoCAD that can be display in Naviwork Properties, is it possible?
I'm using AutoCAD 2011 and Visual Express 2010
ADN Support Specialist
xiaodong.liang
Message 2 of 4 (186 Views)
Re: What data read by Naviswork
01-21-2013 09:24 PM in reply to: AbuFaisal
for native AutoCAD entity, you have to add the additional properties on the file of the Navisworks format. i.e. after the original DWG is converted to nwd, iterate the model items and add the properties to them by Navisworks API.
for the custom entity, please refer to
http://adndevblog.typepad.com/aec/2013/01/display-custom-properties-of-dwg-in-navisworks-1.html
http://adndevblog.typepad.com/aec/2013/01/display-custom-properties-of-dwg-in-navisworks-2.html
currently, no way (or no options) to import xdata to Navisworks
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Message 3 of 4 (173 Views)
01-24-2013 06:18 PM in reply to: xiaodong.liang
Hi xiaodong.liang
I'm installing visual express now, so I can't install Object ARX. However I look to your website to following address : http://adndevblog.typepad.com/aec/2012/05/create-attributes-and-properties-for-model-objects-using-n...
which looks like can do what I want.
The problem is I'm a real dummy in naviswork, can you tell me how to load dll file we created, and is it also possible to run our code without running the naviswork software? I have checked to the documentation but still confusing for me
xiaodong.liang
Message 4 of 4 (162 Views)
01-28-2013 07:22 PM in reply to: AbuFaisal
do you mean Navisworks plugin dll file?  Please read the tutorial
C:\Program Files\Autodesk\Navisworks Manage 2013\api\net\documentation\NET API.chm >> Developer Guide >> Writing Plug-ins.
If you meant by ObjectARX dll, I'd suggest you get started with by the materials below:
ObjectARX 2013 Training
ObjectARX 2010/2012 Training
Xiaodong Liang
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
