Navisworks API
New Member
Message 1 of 6 (432 Views)
Accepted Solution
Unable to add custom properties to all desired modelitems
432 Views, 5 Replies
02-15-2013 05:45 AM
Dear all,
Could you please help me with the following. I wrote a Navisworks Manage 2013 Plug-in which takes a model and adds requirements to it from an external source. All fine on that part. Somewhere in the routine I loop through the selectionsets I created.
The trick now is, I want to assign to each modelitem of that selectionset the requirements as a custom property. I am able to do so using the ComApi/ComApiBridge (code given below).
// get the selection in COM
ComApi.InwOpSelection comSelectionOut =
	ComApiBridge.ComApiBridge.ToInwOpSelection(aSelSet.ExplicitModelItems );
foreach ( ComApi.InwOaPath3 oPath in comSelectionOut.Paths() )
	// get properties collection of the path
	ComApi.InwGUIPropertyNode2 propn =
		(ComApi.InwGUIPropertyNode2)state.GetGUIPropertyNode(oPath, true);
	// add the new property category to the path
	propn.SetUserDefined(0, "Eisen",
						 "Eisen", newPvec);
The result is that when I select an object in the model it perfectly shows the Requirements tab called "Eisen". See the picture below (ps. dont worry that there are two tabs showing "Eisen", thats correct (for now :-) ).
I now want to have the Requirements showing in the 'Child' of those ModelItems as well, that is in the case of the example given above, the 'Solid' (see picture below). I have been trying to do so with all sorts of methods from the ComApi, but I just am not able to succeed.
I tried things like the code snippet below, but just cant get it to work.
ComApi.InwGUIPropertyNode2 propn2 =
	(ComApi.InwGUIPropertyNode2)state.GetGUIPropertyNode(oPath.Nodes().Last, true);
Could you please point me in the right direction on how to get the Requirement (i.e. "Eisen") also at the ModelItem "Solid" (and others).
Thanks in advance!
All the best,
Jeroen
ADN Support Specialist
xiaodong.liang
Message 2 of 6 (411 Views)
Re: Unable to add custom properties to all desired modelitems
02-19-2013 06:55 PM in reply to: jvisser.autodesk
probably the following workflow could help.
     ModelItemCollection oMC = Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentSelection.SelectedItems;
             // add property to additional paths
            foreach (ModelItem oEachItem in oMC)
                // check if oEachItem.Children is empty
                //check if each child node is within the current selection
                //or check the geometry node directly
                // convert the child node to a path e.g.
                //ComApi.InwOaPath oAdditionalPath = ComApiBridge.ComApiBridge.ToInwOaPath(oEachItem);
                //ComApi.InwGUIPropertyNode2 propn =
                //    (ComApi.InwGUIPropertyNode2)state.GetGUIPropertyNode(oAdditionalPath, true);
                //propn.SetUserDefined(0, "Eisen",
                //                     "Eisen", newPvec);
             // continue to add property to the selected paths.
            foreach (ComApi.InwOaPath3 oPath in comSelectionOut.Paths())
                                     "Eisen", newPvec);
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
New Member
Message 3 of 6 (378 Views)
03-01-2013 06:16 AM in reply to: xiaodong.liang
Dear Xiaodong,
Your solution is (again :-) ) spot on. I modified it a little so I can have the two in one go. Final routine looks like this:
			// add property to paths
				ComApi.InwOaPath oPath = ComApiBridge.ComApiBridge.ToInwOaPath(oEachItem);
				                      "Eisen", newPvec);
				// I want to add the Eisen to the 'geometry' level as well.
				if (oEachItem.Children.First != null)
					ComApi.InwOaPath oAdditionalPath = ComApiBridge.ComApiBridge.ToInwOaPath(oEachItem.Children.First);
					propn2.SetUserDefined(0, "Eisen",
					                     "Eisen", newPvec);
Thank you very much for the solution. I will close this thread with 'solution accepted'.
Best regards,
Jeroen
xiaodong.liang
Message 4 of 6 (357 Views)
03-04-2013 06:36 PM in reply to: jvisser.autodesk
Hi, Jeroen,
you made it much elegant!  Glad to know it  solved your question. Thank you sharing the updated code :smileyhappy:
Xiaodong Liang
Active Contributor
Message 5 of 6 (288 Views)
04-01-2013 05:39 PM in reply to: xiaodong.liang
Hi guys,
Can you show the code where you create the newPvec object?
thanks,
xiaodong.liang
Message 6 of 6 (280 Views)
04-02-2013 08:26 PM in reply to: ngombault
please refer to this post:
http://adndevblog.typepad.com/aec/2012/05/create-attributes-and-properties-for-model-objects-using-n...
Xiaodong Liang
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
