I am saving the Camera params from a Saved View into a database.
var oView = _state.CurrentView.ViewPoint as nw.InwNvViewPoint2; var camera = oView.Camera; var scv = new SavedCameraView(); scv.Name = viewName; scv.AspectRatio = camera.AspectRatio; scv.HeightField = camera.HeightField; scv.PostionData1 = camera.Position.data1; scv.PostionData2 = camera.Position.data2; scv.PostionData3 = camera.Position.data3; scv.Projection = (int)camera.Projection; scv.RotationAngle = camera.Rotation.angle;
I want to be able to recreate this SavedView on reentering the model but reconstructing it from the saved camera params.
Here is my attempt.
InwSavedViewsColl savedViews = _state.SavedViews(); InwOpView sv = (InwOpView)_state.ObjectFactory(nwEObjectType.eObjectType_nwOpView, null, null); sv.name = scv.Name; //sv.anonview = (InwOpAnonView)_state.CurrentView; var camera = (InwNvCamera)_state.ObjectFactory(nwEObjectType.eObjectType_nwNvCamera, null, null); var viewPoint = (InwNvViewPoint2)_state.ObjectFactory(nwEObjectType.eObjectType_nwNvViewPoint, null, null); var axis = (InwLUnitVec3f)_state.ObjectFactory(nwEObjectType.eObjectType_nwLUnitVec3f, null, null); //axis.data1 = 0; //axis.data2 = 0; //axis.data3 = 0; camera.AspectRatio = scv.AspectRatio.Value; camera.HeightField = scv.HeightField.Value; camera.Position.data1 = scv.PostionData1.Value; camera.Position.data2 = scv.PostionData2.Value; camera.Position.data3 = scv.PostionData3.Value; camera.Projection = (nwEProjection) scv.Projection; camera.Rotation = (InwLRotation3f)_state.ObjectFactory(nwEObjectType.eObjectType_nwLRotation3f, null, null); camera.Rotation.SetValue(axis, scv.RotationAngle.Value); viewPoint.Camera = camera; sv.anonview.ViewPoint = viewPoint; savedViews.Add(sv);
The issue is that Camera.Rotation.angle is not set. You cannot set it directly as it is read only.
If I run the code as is, the reconstructed SavedView has Rotation angle =0, and AspectRatio and HeightField are incorrect.
I assume I need to do some Vector maths here instead of what I am doing?
How can achieve this step?
have you tried InwLRotation3f.SetValue? It is to set axis and angle.
That would be this line in my code..
I believe the Error is that you do not set the Axis
var axis = (InwLUnitVec3f)_state.ObjectFactory(nwEObjectType.eObjectType_nwLUnitVec3f, null, null); axis.SetValue(10.00, 10.00, 10.00);
I hope this Helps....
Colin
