Navisworks API
ssdiesel
Message 1 of 8 (386 Views)
Accepted Solution
Project units
386 Views, 7 Replies
09-11-2012 09:15 AM
Hello!
I want to merge my dxf file with navis drawing:
Autodesk.Navisworks.Api.Document doc = Autodesk.Navisworks.Api.Application.ActiveDocument;
                    if (doc.TryMergeFile(@"C:\test1.dxf"))
                        MessageBox.Show("Merge successful.");
 But when i merge this files.I open Tree Structure. Navis project has units "Inches", but test1.dxf has milimetres.
How can i set inches?
ADN Support Specialist
xiaodong.liang
Message 2 of 8 (377 Views)
Re: Project units
09-19-2012 08:35 PM in reply to: ssdiesel
Using the .NET API, we can get the value of the Units for a document using the Document.Units() property. But it returns the units of the first model only. And setting the value is not possible since this property is read-only.
Using the COM API does not either help since the part.LinearUnits (where part is InwOaPartition2) is read-only and does not allow us to set the units.
We have had wish to provide the API to set units.
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
ssdiesel
Message 3 of 8 (372 Views)
Re: Project units
09-19-2012 09:32 PM in reply to: xiaodong.liang
Thx for answer! I found the way to set units without API and COM, but with external application. But for launnch this application i need use external C# reference. I am add this dll in a references. But when i try use some procedures or functions in my plugin Naviworks crash with fatal error.. I tryed to connect other dll (maybe those dll has any errors) wich i wrote by myself, wich show message only.. and the same result Nws was crashed. Is there the way to use external reference?
xiaodong.liang
Message 4 of 8 (360 Views)
Re: Project units
09-24-2012 08:59 PM in reply to: ssdiesel
The external reference of Navisworks plugin must be put within  <Navisworks installation path>\Dependencies\.
I am interested in how you set the unit :smileyhappy: Did you get the handle of the dialog and swtich to the control of the Unit, and mimic changing unit? Is it possible to share some hints? Thank you!
Xiaodong Liang
ssdiesel
Message 5 of 8 (354 Views)
Re: Project units
09-25-2012 08:49 PM in reply to: xiaodong.liang
thanks for answer.
well for set units i used some scripts and windows handler. i think its wrong. but...
first of all i get screen size,then automaticaly press "structure view"  button, this button i check by coordinates,
after i try to find this window, then press other button etc
well i know that awful desition, but it works.
Best Regards,
Sergey
Active Contributor
Message 6 of 8 (157 Views)
Re: Project units
11-05-2013 02:22 AM in reply to: xiaodong.liang
Hi all,
Is there any updates on setting unit in api?
John
xiaodong.liang
Message 7 of 8 (130 Views)
Re: Project units
11-17-2013 07:48 PM in reply to: JohnHon
Hi John,
This is still a wish
#11542: Ability to set the units of a document using .NET API.
I did not hear an update on this. Sorry if this is bad news for you.
Xiaodong Liang
Active Contributor
Message 8 of 8 (114 Views)
Re: Project units
11-17-2013 09:27 PM in reply to: xiaodong.liang
Hi Xiaodong.
Sad to hear this news.
How about using Naviswork to change the unit of the model?Is it possible?
John
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
