Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Hyperlink from Cadduct
2 REPLIES 2
Peter-Stephens
389 Views, 2 Replies
I'm importing a model from Autodesk Fabrication CADMEP 2013 (Cadduct as it was called before) into Navis Simulate 2013 and I have hyperlinks in my original CADMEP file that I want to be able to use in my Navis model - is this possible, and if so what do I need to set to be able to do it please.
Thanks in advance
Peter Stephens
2 REPLIES 2
Ixath
in reply to: Peter-Stephens
Options (F12) -> Interface -> Links
I've never messed with the options under the Links menu before but it has a category for Hyperlink. This is probably what you're looking for.
If not, try:
Options (F12) -> Interface -> Quick Properties
Enable Show Quick Properties.
Quick Properties -> Definitions
Category: Hyperlinks (add both Name / URL)
Also check in the Category section for anything related to FABMEP and see if it's there. I'm not sure what category will display it.
xiaodong_liang
in reply to: Ixath
Hi Peter-Stephens,
I doubt if Navisworks could identify the hyperlinks created by the orignal CAD file. but you could give it a try with Ixath's suggestions.
If none solved the question, you may have to create the corresponding hyperlinks of Navisworks with the information from the original CAD file.
Rail Community
