Dear all:
I want to change Field of View (F.O.V) = 90° through Navisworks API, how can do that?
Thanks!
Chao-Yung
Solved by xiaodong_liang. Go to Solution.
Hi
did you find Viewpoint.HeightField ?
Defines camera field of view in combination with aspect ratio. For a perspective camera, this is the vertical field of view (the angle between top and bottom planes of the camera view frustum). For an orthographic camera, this is the distance between top and bottom planes of the camera view frustum. Default 0.785398 (45 degrees)
Does anyone know if there is a way to change the default setting for Field of View in Navisworks?
I'm trying to figure out where to go to find Viewpoint.HeightField and what to do once i find it to resolve the F.O.V issue.
Not sure of the procedure to do so. Can you give a step by step please?
Thank you,
