Navisworks API
ssdiesel
Message 1 of 17 (314 Views)
Get all selected viewpoint
314 Views, 16 Replies
08-16-2012 11:17 AM
Hello!
i need to get list of selected viewpoints , but i can get only last selected view.
and also how can i get position of viewpoint?
Thx
ADN Support Specialist
xiaodong.liang
Message 2 of 17 (300 Views)
Re: Get all selected viewpoint
08-21-2012 06:10 PM in reply to: ssdiesel
I am not sure if you are the guy who asked the similar question recently on our blog. The followingis what I replied there:
Yes, CurrentSavedViewpoint tells the last selected view points only. Can I know why you want to know the multi-selected items? As I know, only one saved viewpoint can be applied to the current view. If what you wanted is to do some post work after the user multi-selected the viewpoints, I would suggest you create your own panel to manage the viewpoints. Thus you can know multi-selected easily.
As to position of the viewpoint, it is stored with the camera of the viewpoint contains.
1) before 2013, you will need to use COM API    e.g.
     Com.InwNvCamera cam = m_state.CurrentView.ViewPoint.Camera;
     Com.InwLPos3f oPos = cam.Position;
      // .... other properties
2) from 2013, .NET API provides the relevant objects. Pleae refer to the blogs:
   http://adndevblog.typepad.com/aec/2012/06/navisworks-net-api-2013-new-feature-viewpoint-1.html
    http://adndevblog.typepad.com/aec/2012/06/navisworks-net-api-2013-new-feature-viewpoint-2.html
    http://adndevblog.typepad.com/aec/2012/06/navisworks-net-api-2013-new-feature-viewpoint-3.html
   http://adndevblog.typepad.com/aec/2012/06/navisworks-net-api-2013-new-feature-saved-viewpoint.html
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
ssdiesel
Message 3 of 17 (296 Views)
08-21-2012 06:19 PM in reply to: xiaodong.liang
Hello!
yes its me again.
well i solved this the next folowing (as you sad):
created new dock panel transfer all data from viewpoint,
actually now am working with clash.
but unfortunally Navis cant work with multi - selection.
And btw, i want use multi-select for package renaming pointviews.
Thx for reply
xiaodong.liang
Message 4 of 17 (291 Views)
08-21-2012 06:39 PM in reply to: ssdiesel
glad it helps. yes, you could manage flexibly in your own tree. The built-in trees of Navisworks do not always meet the requirement of customization.
Xiaodong Liang
ssdiesel
Message 5 of 17 (289 Views)
08-21-2012 06:43 PM in reply to: xiaodong.liang
thats right! you absolutly right!
some users dont want to work with newly panels, and want to use standarts panels.
but standarts panels and instuments have a limit.
btw, one more thing. can you tell me when i select viewpoint in mypanel tree, how can i select the same in Navis, i mean that Navis show me a view from this point?
xiaodong.liang
Message 6 of 17 (285 Views)
08-21-2012 06:57 PM in reply to: ssdiesel
Same to the original question, since API cannot tell the multi-selection, it cannot either apply multi-selection. CurrentSavedViewPoint is a single select. Probably we could setup a wish if it has strong use cases.
In product, the scenarios when the user wants to multi-select may be:
-          Move them the one folder together
-          Add a copy with these selected items
-          Edit their common properties
-          Transform them with same transformation
-          etc….
In a word, the aim is to get a result, instead of just showing they are multi-selected.
So I think, when your user multi-selects in your own tree, he could decide what he what to do. And your program provides the ability to do what he wants. He does not need to concern switch back-forth between the built-in tree and your tree.
Xiaodong Liang
ssdiesel
Message 7 of 17 (283 Views)
08-21-2012 07:07 PM in reply to: xiaodong.liang
sorry, but now i mean not multiselection.
i mean, when we selectin some viewpoint in a "Saved viewpoints" panel, Navis shows this point view in a model.
how can i make it with my panel of viewpoints tree?
xiaodong.liang
Message 8 of 17 (279 Views)
08-21-2012 07:21 PM in reply to: ssdiesel
it sounds you need to apply the saved viewpoint (if multi-selection, the last saved viewpoint) to the current viewpoint in model? If yes, with COM API, you can just call state.ApplyView with the last saved viewpoint. If you are working with 2013, you can use pure .NET API to manage, e.g. oDoc.SavedViewpoints.CurrentSavedViewpoint =  oLastSavedViewPoint;
Xiaodong Liang
ssdiesel
Message 9 of 17 (277 Views)
08-21-2012 07:27 PM in reply to: xiaodong.liang
Thanks alot!
You very help me!
ssdiesel
Message 10 of 17 (264 Views)
08-22-2012 05:36 AM in reply to: ssdiesel
btw i am noticed a little strange.
when i get viewpoint position (SavedItem.Viewpoint.Position.X,Y,Z) and after that i am compare with coordinate (viewpoint>edit>position) those data have not same values.
for example
SavedItem.Viewpoint.Position.X = 2028,7496
but in a property window Position X = 71,74
why that happens?
thx
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
