Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Finding Display Units and Fractional Display Precision?
6 REPLIES 6
13235 Views, 6 Replies
I'd like my plugin to automatically use the information on the INTERFACE -> DISPLAY UNITS page (Linear Units, Decimal Places, and Fractional Display Precision) so I can format my text boxes to match the users current setup...but I can't figure out where these values are stored.
Is this something I'm able to do? If so, where is the data stored?
I was thinking I could read from a pre-existing config file if I had to, but nothing I saw contained this data either. I think I'm just blind?
edit:
So it looks like I might have found where to start:  Autodesk.Navisworks.Internal.ApiImplementation.ApplicationConfig... or not.
6 REPLIES 6
xiaodong_liang
The officcial .NET API has not exposed the abilities with Global Options. You could get the values from registry at:
HKEY_CURRENT_USER\Software\Autodesk\Navisworks Manage x64\11.0\GlobalOptions\interface\disp_units
in reply to: xiaodong_liang
Additionally, does the API currently expose the ability to access the specific per file/model unit as specified under the "Units and Transform" dialog accessable via the Selection Tree?
xiaodong_liang
.NET API provides Document.Units and Model.Units.
Somewhy in NW Manage x64 2014 GlobalOptions doesn't exist at HKEY_CURRENT_USER\Software\Autodesk\Navisworks Manage x64\11.0\ on Windows 8 machine. Can these settings be hiden elsewhere?
xiaodong_liang
I have no Win8 at this moment. could you provide a snapshot on the problem? Thank you!
You can read it.
This is for converting to mm:
double conv = UnitConversion.ScaleFactor(Application.MainDocument.Units, Units.Millimeters);
Rail Community
