We're converting NWC to NWD, but the resulting NWD files are locked.
So we need a method to batch convert NWC + NWF files to NWD while enabling the flag: ALLOW_RESAVE
How do we enable this flag using vbscript or .NET?
Solved by xiaodong_liang. Go to Solution.
When you use Publish to generate the nwd file, you can set the flag:
.NET API: PublishProperties.AllowResave . refer to api\net\documentation\.NET API.chm to find the sample
COM API: InwOaPublishAttribute.Flags = nwEPublishFlags .ePublishFlag_ALLOW_RESAVE . refer to api\com\examples\auto_08, you can know how to se attributes.
Gents,
I am struggling to make this work using Navisworks 2016.
I am trying to publish a .rcs from recap into a .nwd with embedded textures. This works but even with the flag allow resave, the resulting file cannot be re-saved on itself: if I open the nwd and save it as yet a new nwd, the new file is fine, but if try to just save it on itself I get an error 'cannot open file for writting'.
Unfortunately when I use the API to do this convoluted workflow (publish as temp name > open > save as new name) the new resulting file has the same problem. So it looks like the Navisworks UI 'Save As' function does something differently form the API.
Any advice?
Nic
