Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Cannot load suitable Navisworks runtime
4 REPLIES 4
JohnHon
1415 Views, 4 Replies
Dear all,
I am creating a window form application with document control and view control.
When I run following code, an exception occurs.
Autodesk.Navisworks.Api.Controls.ApplicationControl.Initialize()
RuntimeLoaderException
Cannot load suitable Navisworks runtime. Note that 32bit Navisworks Controls are not supported on 64bit OS except in DesignMode
For your information, I am using Visual Studio 10 and Navisworks Manage 2013.
Also, Autodesk.Navisworks.Controls.dll is added to the reference.
For Controls.dll,
Runtime Version:v4.0.30319
version:10.0.840.82
My PC is windows 7 Professional and both PC and Navisworks are 64- bit.
Could you help me to solve it?
John
4 REPLIES 4
xiaodong_liang
in reply to: JohnHon
Hi John,
please check the project setting if you configured to X86. By default, VS creates the standalone EXE with X86 (this default setting can be configured, I believe). In runtime, a X86 EXE will try to load the X86 modules, but
.NET modules of Navisworks .NET API is 64bits on 64bits machine. So either change to X64, or Any CPU.
JohnHon
in reply to: xiaodong_liang
Dear Xiaodong,
Thanks for your answer. I change it to Any CPU and it works!
John
ericjoe
Hi, I have changed the Configuration Manager to "x86" and "Any CPU".
However, I still face the same error message.
Autodesk.Navisworks.Api.RuntimeLoaderException was unhandled
  HResult=-2146233079
  Message=Cannot load suitable Navisworks runtime
  Source=Autodesk.Navisworks.Api
  StackTrace:
       at Autodesk.Navisworks.Internal.ApiImplementation.ApplicationImpl.InitialiseErrorHandling(ApplicationConfig config)
       at Autodesk.Navisworks.Internal.ApiImplementation.ApplicationImpl.InitialiseResources(ApplicationConfig config)
       at Autodesk.Navisworks.Internal.ApiImplementation.ApplicationImpl.InitialiseApi(ApplicationConfig config)
       at Autodesk.Navisworks.Api.Controls.ApplicationControl.InitializeImpl()
       at Autodesk.Navisworks.Api.Controls.ApplicationControl.Initialize()
       at Viewer.Program.Main() in C:\Working_Place_Joe\AMNIS\Technical Issue\Navisworks\Navisworks_2016_API_Training_Labs\Individual labs\Nw_Single_Doc_With_View\Program.cs:line 44
       at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
       at System.AppDomain.nExecuteAssembly(RuntimeAssembly assembly, String[] args)
       at System.Runtime.Hosting.ManifestRunner.Run(Boolean checkAptModel)
       at System.Runtime.Hosting.ManifestRunner.ExecuteAsAssembly()
       at System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext, String[] activationCustomData)
       at System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext)
       at System.Activator.CreateInstance(ActivationContext activationContext)
       at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssemblyDebugInZone()
       at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       at System.Threading.ThreadHelper.ThreadStart()
  InnerException:
Can you advise me what should I do?
Thank you.
Ganesh7
in reply to: ericjoe
If your Navisworks is 64Bit, change the setting of VS to x64 and try to compile,
Rail Community
