Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Adding a custom Task to Timeliner (or adding model selections to tasks)
3 REPLIES 3
tkachenko_truboprovod
1473 Views, 3 Replies
Hi everybody!
I have to write a plugin, which adds some selection to every timeliner task. By selection i mean Autodesk.Navisworks.Api.Timeliner.TimelinerSelection class.
So, after user imports an MS Project file as a timeliner datasource, i get the timeliner object, i'm able to iterate through tasks and their children, BUT....
but i cannot write anything to a task or timeliner object - they are all read-only. I read about it in Developers Guide(collections returned by Navisworks are read-only, collections created programmatically are writeabe), i see ReadOnly == true in objects' properties, but i hope there is a solution for this.
So, does anybody know how to WRITE data to timeliner Tasks using .NET API?
This is how i get access to timeliner object:
public class navisTest :AddInPlugin
    {        static Document navDoc = Autodesk.Navisworks.Api.Application.ActiveDocument;
        static Autodesk.Navisworks.Api.DocumentParts.IDocumentTimeliner Itimeliner = navDoc.Timeliner;
        static DocumentTimeliner timeliner = (DocumentTimeliner)Itimeliner;
        TimelinerTask tsk = new TimelinerTask();
        foreach (TimelinerTask task in timeliner.Tasks)
            foreach (TimelinerTask childTask in task.Children)
                if (!childTask.Selection.IsClear)
                    childTask.Selection.CopyFrom(newCollection);  //some  ModelItemCollection
                    //or CopyFrom(navDoc.CurrentSelection.SelectedItems.DescendantsAndSelf);
                    //anyway it crashes here - "object is readonly"
Also, i tried to create my own Task object and add it to timeliner - the same thing, it crashes:
tsk.Selection.CopyFrom(navDoc.CurrentSelection.SelectedItems.DescendantsAndSelf);
timeliner.Tasks.Add(tsk);  //crashes here.
Thanks in advance,
Alexander.  Cat Happy
3 REPLIES 3
The task cannot be manipulated directly. Please refer to the following code:
          GroupItem root_copy = timeliner.TasksRoot.CreateCopy() as GroupItem;
          try
              root_copy.Children.Add(tsk);  //crashes here.
                // replace the timeliner tasks
              timeliner.TasksCopyFrom(root_copy.Children);
          catch (Exception ex)
Thanks a lot!
I've already found this solution yesterdeay, and you verified my guess!
Alexander.
Hello @tkachenko_truboprovod I am facing a similar issue right now. I just want to ask you or Mr. @xiaodong_liang what exactly does this code do? You are just adding a task to the Timeliner? Or is there a way to add several in different point throughout the Timeliner?
Hope you can help,
Kind Regards
Tags (3)
Rail Community
