I'm trying to set the close files on open option so that i may update the nwd file that everyone is looking at on a webpage. I know in Navisworks you can set the options when you load a file. Does anyone know what you need to put in the code to set this option? This way if someone leaves the page open i can still update the nwd file. Here is the code i have.
<OBJECT id=NWControl01 codeBase="nw_ax_lite.cab" classid=CLSID:5E522D92-AED8-47ff-9AB6-DDA03592D660> <PARAM NAME="_cx" VALUE="32000"> <PARAM NAME="_cy" VALUE="18600"> <PARAM NAME="SRC" VALUE="C:\REVIEWS\HTML\UPM.nwd"> </OBJECT>
As I know, no an API for this option. But probably there is a registry to configure it, which I do not know...
