Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
API navisworks
1 REPLY 1
MICABIM
695 Views, 1 Reply
API navisworks
Hi All,
am trying to do an API for Navisworks in the space of the animation, how I get the coordinates of the animation and how I can remove or copy movements to animator made ​​in order to use the API, I would greatly appreciate your help
1 REPLY 1
xiaodong_liang
in reply to: MICABIM
Hi MICABIM ,
Frankly speaking, I am not clear on your question. As I am aware, the available API (COM) with animation are:
InwOpState .CurrentAnimation: get current animation.
InwOpAnimView: represents a named animation. Two properties:
     Looped: Determines if the animation will keep looping indefinitely.
     Smoothing: Interpolation method used between key frames.
InwControl. AnimationCommand:  Processes an animation command in ActiveX control
<NW installation path>\api\COM\examples\ACTX_02 is a sample using the ActiveX control embedded in a VB application to create and playback animated model walkthroughs.
Best regards,
Xiaodong Liang
Developer Consultant
Autodesk Developer Technical Services
Rail Community
