writing attribute values
I'm trying to write some code that adds values to attributes of a specified block.
I'm able to search for the block, but I'm having trouble aditing it...
Dim acDoc AsDocument = Application.DocumentManager.MdiActiveDocument
Dim acCurDb AsDatabase = acDoc.Database
Dim acTransMgr As Autodesk.AutoCAD.DatabaseServices.TransactionManager= acCurDb.TransactionManager
Using acTrans1 AsTransaction= acTransMgr.StartTransaction
Dim acBlkTbl AsBlockTable = acTrans1.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
If acBlkTbl.Has("blockname") Then
    *** here I need to get the object found in the active block table and edit it's attributes by atribute name ****
End Using
I hope aomebody was some simple-sample code I can use!!
Thanx,
Marc
truss_85
Below code you can edit att values by block
you can use it like
SetAttribute(ObjectId of block, "BLOCKNAME", "ATTNAME", "ATTVALUE")
Public Sub SetAttribute(ByVal BlockID As Autodesk.AutoCAD.DatabaseServices.ObjectId, ByVal blckname As String, ByVal AttTag As String, ByVal AttVal As String)
        Dim MyDb As Database = Application.DocumentManager.MdiActiveDocument.Database
        If BlockID.IsNull Then Exit Sub
        Try
            Using myTrans As Transaction = MyDb.TransactionManager.StartTransaction
                Dim myBlckRef As BlockReference
                Dim myAttColl As AttributeCollection
                Dim myBlckTable As BlockTableRecord
                myBlckRef = BlockID.GetObject(OpenMode.ForWrite)
                If myBlckRef.IsDynamicBlock Then
                    myBlckTable = myTrans.GetObject(myBlckRef.DynamicBlockTableRecord, OpenMode.ForRead)
                Else
                    myBlckTable = myTrans.GetObject(myBlckRef.BlockTableRecord, OpenMode.ForRead)
                If String.Compare(myBlckTable.Name, blckname, True) = 0 Then
                    myAttColl = myBlckRef.AttributeCollection
                    Dim myEnt As Autodesk.AutoCAD.DatabaseServices.ObjectId
                    Dim myAttRef As Autodesk.AutoCAD.DatabaseServices.AttributeReference
                    For Each myEnt In myAttColl
                        myAttRef = myEnt.GetObject(OpenMode.ForWrite)
                        If String.Compare(myAttRef.Tag, AttTag, True) = 0 Then
                            myAttRef.TextString = AttVal.ToString
                    Next
                myTrans.Commit()
            End Using
        Catch ex As Exception
        End Try
    End Sub
Thanks for this!
The only thing; I don't know what to use in the ObjectId of block in the line:
Marc
truss_85
I send you whole class
Maybe it is helpful for you. object id is block object.objectid in short property of object
Take a look at the code; the main sub create a selection set on screen and filter all the blocks
in selection set then changed desired blocks att with SetAttribute Sub.
Let me know if it is helpful...
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Public Class Class1
    <CommandMethod("SBEA")> _
    Public Sub SBlocksEditAtts()
        Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                Dim acTypValAr(0) As TypedValue
                acTypValAr.SetValue(New TypedValue(DxfCode.Start, "INSERT"), 0)
                Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
                Dim prselres As PromptSelectionResult = acDocEd.GetSelection(acSelFtr)
                If prselres.Status = PromptStatus.OK Then
                    Dim acSSet As SelectionSet = prselres.Value
                    Dim nn As Integer = 0
                    For Each acSSObj As SelectedObject In acSSet
                        SetAttribute(acSSObj.ObjectId, "BLOCKNAME", "ATTNAME", nn.ToString)
                        nn = nn + 1
                    Next
                    acDocEd.WriteMessage("Number of objects selected: " & acSSet.Count.ToString())
	    acTrans.Commit()
        End Using
    End Sub
        Try
                Else
                    Next
                myTrans.Commit()
            End Using
        End Try
    End Sub
End Class
chiefbraincloud
What the OP needs to realize is that the code as posted would be looking at BlockTableRecords, and what he really needs is BlockReferences.
That said, there have been countless posts on that subject over the last few years, so rather than re-hashing the same old stuff, I would suggest you do a search on this group, and you could also get some info by doing a search on the Through the Interface blog.
Try this one:
http://through-the-interface.typepad.com/through_the_interface/2007/07/updating-a-spec.html
