.NET
what reference do i need to add?
1 REPLY 1
164 Views, 1 Reply
I'm learning use VB.net to customize AutoCAD 2006. what do i normally import before programing? I already added the Autodesk reference.
Thanks in advance.
Johnson z
1 REPLY 1
John,
If you are programming using the .net api of autocad 2006 then just the
following would do :
acdbmgd.dll
acmgd.dll
Cheers,
Tilz
wrote in message news:5090459@discussion.autodesk.com...
Thanks in advance.
Johnson z
”Boost
