• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    vb.net routine - autocad says unkown command
    143 Views, 2 Replies
    03-03-2012 02:46 PM
    I have no idea why autocad 2012 refuses to load this, or it is loading it but something else is causing the command to not be known.
    I have no errors in visual studio & I get no errors when I netload.
    I'm sure there are logic errors since I haven't been able to debug this yet (migrating it from VBA to VB.NET)
    any help would be appreciated.
    the start point / command is in Class2 in vbLayerGroupController
    ACF & ACGen contain functions called by my routine.
    While trying to figure this out, as a test, I had created a new class with a generic msgbox command within this project & it worked (I removed it now), so there is something in here that autocad doesn't like.
    Please use plain text.
    *Expert Elite*
    Re: vb.net routine - autocad says unkown command
    03-03-2012 06:47 PM in reply to: kcimos
    In your class2.vb file, add this line after the "Imports..." instruction and before the class LayerGroupController, like this:
    Imports Autodesk...
    Imports .....
    <Assembly: CommandClass(GetType(LayerGroupController))>
    Class LayerGroupController
        <CommandMethod("LKK")>_
        Public Sub LayerGroupController()
        End Sub
    EndClass
    HTH
    Valued Contributor
    03-03-2012 08:08 PM in reply to: norman.yuan
    that worked.
    what is it? why?
    I don't have that in any other projects that work.
    thanls.
    I would have NEVER figured that out.
    also, useful tip for anyone out there (maybe):
    I set option strict  = ON, & a lot of errors revealed themselves.
    I've been leaving it off because there always ends up being at least one thing I can't resolve, like with this program there was one late binding error (keep in mind I haven't begun to debug this yet since I haven't yet been able to enter my command in autocad to start the process):
    ForEach Ent AsObjectInACF.ThisDrawing.PaperSpace
    If Ent.ObjectName = "AcDbViewport"Then
