• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    vb.net generic list
    450 Views, 12 Replies
    11-16-2012 08:40 AM
    I created a class with about 40 properties in it
    In another class I have created of generic list of the above class (lets just call it "A" here, & the list "Alist")
    It seemed to me that the best way of populating my list would be to create a temporary variable of type "A" (let's call it "tempA"), do a wide variety of things to set the various properties of tempA, which involves creating a bunch of different objects (layer table records for example), and then adding tempA to Alist as follows:
    Alist.add(tempA)
    the problem with this is that every item in  my list ends up being a reference to tempA,
    so Instead of using tempA, I just directly set the current list member by keeping track of my count (which now starts getting into the extra code required that I'm trying to avoid by using lists in the first place). But this only "works" if I set the property to an actual value such as TRUE, or 15, etc, otherwise all list memebers still reference the same object such as a layertablerecord. So in a list of layernames that should be "a", "b",..."z", I end up with "z","z",..."z".
    I do not want to create constructors for my class, & end up with :
    Alist.add(layouttype, layoutname,layername,ison,isfrozen, etc, etc & 35 more items would go in this series)
    is there a way to force or convert the referenced data to be byval?
    should I just use an array instead?
    why are lists byref to begin with? what good does that do?
    Please use plain text.
    Distinguished Mentor
    Re: vb.net generic list
    11-17-2012 11:51 PM in reply to: kcimos
    I'm only learning myself but I was having the same problem adding many objects to a list and ended up using the following -
    In a seperate sub/function I had
    Sub AddAtoList()
       tempA = New A
       <code to populate tempA properties>
       Alist.Add(tempA)
       tempA = Nothing
    End Sub
    I'm sure one of the more experienced people can explain far better than me.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    *Expert Elite*
    Re : vb.net generic list
    11-18-2012 05:34 AM in reply to: kcimos
    It seems that you are missing some .NET/OOP basics.
    All classes (except string) are reference type, on the other hand, structures are value type.
    Both List and Array are reference type so using an array instead of a list won't solve your problem.
    If I understand what you're tying to do: populate a list of a 'A' type using the default (without arguments) 'A' constructor to create instances of 'A' (I suppose you set each 'A' instance properties from the class where the list is build).
    so, IMO your problem is due to the way you create each 'A' instance. In the class where you populate the list, you need to explicitly create a New instance of 'A' for each object
    Here's a little sample (not related to AutoCAD):
    C#
    using System;
    using System.Collections.Generic;
    namespace GenericListSample
        class Program
            static void Main()
                List<A> Alist = new List<A>();
                A tempA = new A();
                tempA.Name = "foo";
                tempA.Index = 1;
                tempA.Date = new DateTime(2012, 11, 10);
                tempA.Position = new double[2] { 0.0, 0.0 };
                Alist.Add(tempA);
                tempA = new A();
                tempA.Name = "bar";
                tempA.Index = 2;
                tempA.Date = new DateTime(2012, 11, 12);
                tempA.Position = new double[2] { 10.0, 20.0 };
                Alist.Add(tempA);
                tempA = new A();
                tempA.Name = "baz";
                tempA.Index = 3;
                tempA.Date = new DateTime(2012, 11, 18);
                tempA.Position = new double[2] { 50.0, 30.0 };
                Alist.Add(tempA);
                foreach (A a in Alist)
                    Console.WriteLine("Name: {0}, Index: {1}, Date: {2}, Position: {3}, {4}",
                        a.Name, a.Index, a.Date, a.Position[0], a.Position[1]);
        class A
            public string Name { get; set; } // value type
            public int Index { get; set; } // value type
            public DateTime Date { get; set; } // reference type
            public double[] Position { get; set; } // reference type
    VB
    Imports System
    Imports System.Collections.Generic
    Namespace GenericListSample
        Class Program
            Public Shared Sub Main()
                Dim Alist As New List(Of A)()
                Dim tempA As New A()
                tempA.Name = "foo"
                tempA.Index = 1
                tempA.TheDate = New DateTime(2012, 11, 10)
                tempA.Position = New Double(1) {0.0, 0.0}
                Alist.Add(tempA)
                tempA = New A()
                tempA.Name = "bar"
                tempA.Index = 2
                tempA.TheDate = New DateTime(2012, 11, 12)
                tempA.Position = New Double(1) {10.0, 20.0}
                Alist.Add(tempA)
                tempA = New A()
                tempA.Name = "baz"
                tempA.Index = 3
                tempA.TheDate = New DateTime(2012, 11, 18)
                tempA.Position = New Double(1) {50.0, 30.0}
                Alist.Add(tempA)
                For Each a As A In Alist
                    Console.WriteLine("Name: {0}, Index: {1}, Date: {2}, Position: {3}, {4}", _
                                      a.Name, a.Index, a.TheDate, a.Position(0), a.Position(1))
                Next
            End Sub
        End Class
        Class A
            Private m_Name As String ' value type
            Private m_Index As Integer ' value type
            Private m_Date As DateTime ' reference type
            Private m_Position As Double() ' reference type
            Public Property Name() As String
                Get
                    Return m_Name
                End Get
                Set(value As String)
                    m_Name = value
                End Set
            End Property
            Public Property Index() As Integer
                Get
                    Return m_Index
                End Get
                Set(value As Integer)
                    m_Index = value
                End Set
            End Property
            Public Property TheDate() As DateTime
                Get
                    Return m_Date
                End Get
                Set(value As DateTime)
                    m_Date = Value
                End Set
            End Property
            Public Property Position() As Double()
                Get
                    Return m_Position
                End Get
                Set(value As Double())
                    m_Position = value
                End Set
            End Property
        End Class
    End Namespace
    Another way is to make 'A' type a structure rather than a class. As a structure is  a value type, a new instance will be implictly created.
    Here's the same sample as upper using a structure:
    C#
    using System;
        class Program
            static void Main()
                List<B> Blist = new List<B>();
                B tempB = new B();
                tempB.Name = "foo";
                tempB.Index = 1;
                tempB.Date = new DateTime(2012, 11, 10);
                tempB.Position = new double[2] { 0.0, 0.0 };
                Blist.Add(tempB);
                tempB.Name = "bar";
                tempB.Index = 2;
                tempB.Date = new DateTime(2012, 11, 12);
                tempB.Position = new double[2] { 10.0, 20.0 };
                Blist.Add(tempB);
                tempB.Name = "baz";
                tempB.Index = 3;
                tempB.Date = new DateTime(2012, 11, 18);
                tempB.Position = new double[2] { 50.0, 30.0 };
                Blist.Add(tempB);
                foreach (B a in Blist)
        struct B
    VB
    Imports System
        Class Program
                Dim Blist As New List(Of B)()
                Dim tempB As New B()
                tempB.Name = "foo"
                tempB.Index = 1
                tempB.TheDate = New DateTime(2012, 11, 10)
                tempB.Position = New Double(1) {0.0, 0.0}
                Blist.Add(tempB)
                tempB.Name = "bar"
                tempB.Index = 2
                tempB.TheDate = New DateTime(2012, 11, 12)
                tempB.Position = New Double(1) {10.0, 20.0}
                Blist.Add(tempB)
                tempB.Name = "baz"
                tempB.Index = 3
                tempB.TheDate = New DateTime(2012, 11, 18)
                tempB.Position = New Double(1) {50.0, 30.0}
                Blist.Add(tempB)
                For Each a As B In Blist
                    Console.WriteLine("Name: {0}, Index: {1}, Date: {2}, Position: {3}, {4}", a.Name, a.Index, a.TheDate, a.Position(0), a.Position(1))
                Next
            End Sub
        End Class
        Structure B
                Get
                    Return m_Name
                End Get
                    m_Name = value
                End Set
            End Property
                Get
                    Return m_Index
                End Get
                    m_Index = value
                End Set
            End Property
                Get
                    Return m_Date
                End Get
                    m_Date = value
                End Set
            End Property
                Get
                    Return m_Position
                End Get
                    m_Position = value
                End Set
            End Property
        End Structure
    End Namespace
    Gilles Chanteau
    *Expert Elite*
    Hallex
    11-18-2012 05:51 AM in reply to: andrewpuller3811
    See here for more http://msdn.microsoft.com/en-us/library/6sh2ey19(v=vs.90).aspx
    Generic classes encapsulate operations that are not specific to a particular data type.
    The most common use for generic classes is with collections like linked lists, hash tables,
     stacks, queues, trees and so on where operations such as adding and removing items
     from the collection are performed in much the same way regardless of the type of data
    being stored. See here for more
    You can also to create a list of your classes like this
    : List<List<MyClass>> master= new List<List<MyClass>>();
    to add members to list see methods Add, AddRange,CopyTo etc:
    http://msdn.microsoft.com/en-us/library/d9hw1as6(v=vs.90).aspx
    _____________________________________
    C6309D9E0751D165D0934D0621DFF27919
    Valued Contributor
    11-18-2012 11:56 AM in reply to: kcimos
    _gile,
    let me see if I got this striaght:
    in your example a new instance of the class is created (3 times) with
    Dim tempA = New A()
    tempA = New A()
    & the properties are filled in after each is created.
    & then it it is added to the list via
    Alist.Add(tempA)
    wait a minute, I swear I tried something like that already, except I was using a loop to iterate through all the layers in a  drawing. I had something like this
    for each thingThing as thing in aThingFullOfThings
                tempA = New A
                tempA.Name = "foo"
                tempA.Index = 1
                Alist.Add(tempA)
    next
     but I had  A & Alist declared  as class properties, with shared variables tied to the properties, one of which was a new list (of A).
    could that be causing my problem?
    I'm going to experiment a bit more. I don't need A & AList to be properties actually. I had copied what I did for another project which was my first atttempt using lists & it is unfinished so I never ran into my current problems
    Valued Contributor
    11-19-2012 07:04 AM in reply to: kcimos
    actually, I want to keep my properties in my main procedure class, because they would still be useful here, but manditory in another project, so I really need to figure this out.
    I really don't see any difference between what I'm doing & your example, except for the fact that I'm trying to assign properties of other objects to my list member's properties. If I assign a particular string or an integer or whatever everything works as I expected it too.
    To me it just seems like I need to somehow break the link between the list members' properties & the object's property that I'm extracting the information from such as LayerTableRecord.Name.
    so to try to do this I created a temp variable of class A, & assigned values to its properties such as
    tempA.Layername =LayerTableRecord.Name
    then added tempA to Alist, then set tempA to nothing. Then in the next iteration of reading the layers created a new variable called tempA, (tempA = New A) which to me seems like it should be a new variable called tempA that has nothing to do with the first or 200th variable that was also called TempA. The results of my list is that all memeber's properties reflect the last TempA that was created instead of being unique.
    here is my actual code:
    Public Class FullLayerData
        Private strLayoutName As String
        Private strSpaceName As String
        Private strLayerName As String
        Private strColorName As String
        Private strLinetypeName As String
        Private strLineweightName As String
        Private strPlotStyleName As String
        Private strVpLayerColorName As String
        Private strVpLinetypeName As String
        Private strVpLineweightName As String
        Private strVpPlotStyleName As String
        Private booIsLayout As Boolean
        Private booIsModelSpace As Boolean
        Private booLayerON As Boolean
        Private booLayerFrozen As Boolean
        Private booLayerVpFrozen As Boolean
        Private booLayerNoPlot As Boolean
        Private booLayerNewFrozen As Boolean
        Private booIsColorVpOverridden As Boolean
        Private booIsLinetypVpOverridden As Boolean
        Private booIsLineweightVpOverridden As Boolean
        Private booIsPlotStyleVpOverridden As Boolean
        Private iVpNumber As Integer
        Private colLayerColor As Autodesk.AutoCAD.Colors.Color
        Private colVpLayerColor As Autodesk.AutoCAD.Colors.Color
        Public Property LayoutName() As String
            Get
                Return strLayoutName
            End Get
            Set(ByVal value As String)
                strLayoutName = value
            End Set
        End Property
        Public Property SpaceName() As String
            Get
                Return strSpaceName
            End Get
                strSpaceName = value
            End Set
        End Property
        Public Property LayerName() As String
            Get
                Return strLayerName
            End Get
                strLayerName = value
            End Set
        End Property
        Public Property ColorName() As String
            Get
                Return strColorName
            End Get
                strColorName = value
            End Set
        End Property
        Public Property LinetypeName() As String
            Get
                Return strLinetypeName
            End Get
                strLinetypeName = value
            End Set
        End Property
        Public Property LineweightName() As String
            Get
                Return strLineweightName
            End Get
                strLineweightName = value
            End Set
        End Property
        Public Property PlotStyleName() As String
            Get
                Return strPlotStyleName
            End Get
                strPlotStyleName = value
            End Set
        End Property
        Public Property VpLayerColorName() As String
            Get
                Return strVpLayerColorName
            End Get
                strVpLayerColorName = value
            End Set
        End Property
        Public Property VpLinetypeName() As String
            Get
                Return strVpLinetypeName
            End Get
                strVpLinetypeName = value
            End Set
        End Property
        Public Property VpLineweightName() As String
            Get
                Return strVpLineweightName
            End Get
                strVpLineweightName = value
            End Set
        End Property
        Public Property VpPlotStyleName() As String
            Get
                Return strVpPlotStyleName
            End Get
                strVpPlotStyleName = value
            End Set
        End Property
        Public Property IsLayout() As Boolean
            Get
                Return booIsLayout
            End Get
            Set(ByVal value As Boolean)
                booIsLayout = value
            End Set
        End Property
        Public Property IsModelSpace() As Boolean
            Get
                Return booIsModelSpace
            End Get
                booIsModelSpace = value
            End Set
        End Property
        Public Property LayerON() As Boolean
            Get
                Return booLayerON
            End Get
                booLayerON = value
            End Set
        End Property
        Public Property LayerFrozen() As Boolean
            Get
                Return booLayerFrozen
            End Get
                booLayerFrozen = value
            End Set
        End Property
        Public Property LayerVpFrozen() As Boolean
            Get
                Return booLayerVpFrozen
            End Get
                booLayerVpFrozen = value
            End Set
        End Property
        Public Property LayerNoPlot() As Boolean
            Get
                Return booLayerNoPlot
            End Get
                booLayerNoPlot = value
            End Set
        End Property
        Public Property LayerNewFrozen() As Boolean
            Get
                Return booLayerNewFrozen
            End Get
                booLayerNewFrozen = value
            End Set
        End Property
        Public Property IsColorVpOverridden() As Boolean
            Get
                Return booIsColorVpOverridden
            End Get
                booIsColorVpOverridden = value
            End Set
        End Property
        Public Property IsLinetypVpOverridden() As Boolean
            Get
                Return booIsLinetypVpOverridden
            End Get
                booIsLinetypVpOverridden = value
            End Set
        End Property
        Public Property IsLineweightVpOverridden() As Boolean
            Get
                Return booIsLineweightVpOverridden
            End Get
                booIsLineweightVpOverridden = value
            End Set
        End Property
        Public Property IsPlotStyleVpOverridden() As Boolean
            Get
                Return booIsPlotStyleVpOverridden
            End Get
                booIsPlotStyleVpOverridden = value
            End Set
        End Property
        Public Property VpNumber() As Integer
            Get
                Return iVpNumber
            End Get
            Set(ByVal value As Integer)
                iVpNumber = value
            End Set
        End Property
        Public Property LayerColor() As Autodesk.AutoCAD.Colors.Color
            Get
                Return colLayerColor
            End Get
            Set(ByVal value As Autodesk.AutoCAD.Colors.Color)
                colLayerColor = value
            End Set
        End Property
        Public Property VpLayerColor() As Autodesk.AutoCAD.Colors.Color
            Get
                Return colVpLayerColor
            End Get
                colVpLayerColor = value
            End Set
        End Property
    End Class
    Public Class ClassXLLayerMan
    'a bunch of variable declarations go here, & then...
    Shared liFullLayerDataList As New List(Of FullLayerData)
        Shared fldNewFLD As FullLayerData
        Public Property FullLayerDataList() As List(Of FullLayerData)
            Get
                Return liFullLayerDataList
            End Get
            Set(ByVal value As List(Of FullLayerData))
                liFullLayerDataList = value
            End Set
        End Property
        Private Property NewFLD() As FullLayerData
            Get
                Return fldNewFLD
            End Get
            Set(ByVal value As FullLayerData)
                fldNewFLD = value
            End Set
        End Property
    '...a bunch of subs not directly related to the problem go here, & then...
     Private Sub AddFullLayerDataForEachAutocadVP()
            Dim LayLayout As Layout
            Dim strLayoutName As String
            Dim dictLayouts As DBDictionary
            Dim vpVP As Viewport
            'Dim iVpNum As Integer
            Dim iCurrentCvports As Integer = CInt(Application.GetSystemVariable("CVPORT"))
            Dim iCurrentTilemode As Integer = CInt(Application.GetSystemVariable("TILEMODE"))
            Dim MeaninglessId As ObjectId
            ' Dim FLDcount As Integer
            ' FLDcount = 0
            FullLayerDataList.Clear()
            FullLayerDataList.TrimExcess()
            Using Tx As Transaction = ACF.Db.TransactionManager.StartTransaction
                LT = CType(Tx.GetObject(ACF.Db.LayerTableId, OpenMode.ForRead), LayerTable)
                dictLayouts = CType(Tx.GetObject(ACF.Db.LayoutDictionaryId, OpenMode.ForRead), DBDictionary)
                For Each DE1 As DBDictionaryEntry In dictLayouts
                    If DE1.Key.ToString() = "Model" Then
                        strLayoutName = "Model"
                        LayoutManager.Current.CurrentLayout = strLayoutName
                        Application.SetSystemVariable("TILEMODE", 1)
                        NewFLD = New FullLayerData
                        FullLayerDataList.Add(NewFLD)
                        NewFLD.IsLayout = False
                        NewFLD.LayoutName = strLayoutName
                        NewFLD.IsModelSpace = False
                        NewFLD.SpaceName = "Model"
                        MeaninglessId = DE1.Value
                        'ReadLayerDataFromAutocad(DE1, False, MeaninglessId, FLDcount)
                        ReadLayerDataFromAutocad(DE1, False, MeaninglessId)
                        NewFLD = Nothing
                        'FLDcount = FLDcount + 1
                    Else
                Next DE1
                For Each DE As DBDictionaryEntry In dictLayouts
                    If Not DE.Key.ToString() = "Model" Then
                        LayLayout = CType(Tx.GetObject(CType(DE.Value, ObjectId), OpenMode.ForRead), Layout)
                        strLayoutName = LayLayout.LayoutName
                        For Each id As ObjectId In LayLayout.GetViewports
                            vpVP = CType(Tx.GetObject(id, OpenMode.ForRead), Viewport)
                            NewFLD.VpNumber = vpVP.Number
                            If NewFLD.VpNumber = 1 Then         'first VP should be PS, strVpNum is nothing until first VP is iterated
                                ACF.Ed.SwitchToPaperSpace()
                                Application.SetSystemVariable("cvport", NewFLD.VpNumber)
                                NewFLD.IsLayout = True
                                NewFLD.SpaceName = "PS"
                                NewFLD.VpNumber = NewFLD.VpNumber
                                'ReadLayerDataFromAutocad(DE, True, id, FLDcount)
                                ReadLayerDataFromAutocad(DE, True, id)
                                NewFLD = Nothing
                            Else
                                ACF.Ed.SwitchToModelSpace()
                                vpVP.UpdateDisplay()
                                NewFLD.IsModelSpace = True
                                NewFLD.SpaceName = "MS"
                                NewFLD = Nothing
                        Next id
                Next DE
            End Using
        End Sub
        ' Public Sub ReadLayerDataFromAutocad(ByVal subDE As DBDictionaryEntry, ByRef SubIsLayout As Boolean, ByVal subID As ObjectId, ByRef subFLDcount As Integer)         'SubIsLayout needs to set to false for the model tab, & true for all layout tabs
        Public Sub ReadLayerDataFromAutocad(ByVal subDE As DBDictionaryEntry, ByRef SubIsLayout As Boolean, ByVal subID As ObjectId)
            Dim LTR As LayerTableRecord
            Dim idLineType As ObjectId
            Dim LTTR As LinetypeTableRecord
            Dim LVP As LayerViewportProperties
            Dim vpVP1 As Viewport
            For Each LTRid As ObjectId In LT
                ' Dim supertempFLD = New FullLayerData
                Using Tx1 As Transaction = ACF.Db.TransactionManager.StartTransaction
                    LTR = CType(Tx1.GetObject(LTRid, OpenMode.ForRead), LayerTableRecord)
                    NewFLD.LayerName = LTR.Name
                    NewFLD.ColorName = LTR.Color.ColorNameForDisplay
                    NewFLD.LayerColor = LTR.Color
                    If SubIsLayout = "true" Then
                        LVP = LTR.GetViewportOverrides(subID)
                        vpVP1 = CType(Tx1.GetObject(subID, OpenMode.ForRead), Viewport)
                        If LVP.IsColorOverridden = True Then
                            NewFLD.IsColorVpOverridden = True
                            NewFLD.VpLayerColorName = LVP.Color.ColorNameForDisplay
                            NewFLD.VpLayerColor = LVP.Color
                            'rRange.Font.Color = Col2Str(LVP.Color)          '/<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                        Else
                        If LVP.IsPlotStyleOverridden = True Then
                            NewFLD.IsPlotStyleVpOverridden = True
                            NewFLD.VpPlotStyleName = LVP.PlotStyleName
                        Else
                        If LVP.IsLinetypeOverridden = True Then
                            idLineType = LVP.LinetypeObjectId
                            LTTR = CType(Tx1.GetObject(idLineType, OpenMode.ForRead), LinetypeTableRecord)
                            NewFLD.IsLinetypVpOverridden = True
                            NewFLD.VpLinetypeName = LTTR.Name
                        Else
                        If vpVP1.IsLayerFrozenInViewport(LTRid) = True Then  'freeze = yes
                            NewFLD.LayerVpFrozen = True
                        Else
                    NewFLD.PlotStyleName = LTR.PlotStyleName
                    idLineType = LTR.LinetypeObjectId
                    NewFLD.LinetypeName = LTTR.Name
                    If LTR.IsOff = True Then
                    Else
                        NewFLD.LayerON = True
                    If LTR.IsFrozen = True Then  'freeze = yes
                        NewFLD.LayerFrozen = True
                    Else     'freeze = no
                    If LTR.IsPlottable = True Then 'noplot = no
                    Else
                        NewFLD.LayerNoPlot = True
                End Using
            Next
        End Sub
    Valued Contributor
    11-19-2012 07:11 AM in reply to: kcimos
    sorry guys, I was trying to edit my code to revert it back to another state & I left a few thing out. Please IGNORE the last block of code in my previous post, which should be this:
            ' FLDcount = 0
                        NewFLD = Nothing
                    Else
                Next DE1
                                NewFLD = Nothing
                            Else
                                NewFLD = Nothing
                        Next id
                Next DE
            End Using
        End Sub
                        Else
                        Else
                        Else
                        Else
                    Else
                    Else     'freeze = no
                    Else
                End Using
            Next
        End Sub
    *Expert Elite*
    11-19-2012 12:49 PM in reply to: kcimos
    Sorry it's quite difficult for me to read VB, and the code you posted does not show all the project structure (Namespaces (?), Modules (?) Imports, ...).
    But, from what I can read, the ClassXLLayerMan is absolutely unusefull and does not make the code easily readable.
    I'd use local variables in the AddFullLayerDataForEachAutocadVP() method, for the FullDataLayer and List<fullDataLayer> instances and pass each FullDataLayer instance ByRef to the ReadLayerDataFromAutocad() method.
                Dim layerDataList As List(Of FullLayerData) = New List(Of FullLayerData)
                    newFLD = New FullLayerData
                    ReadLayerDataFromAutocad(DE1, newFLD, False, MeaninglessId)
                Next DE1
            End Sub
            Public Sub ReadLayerDataFromAutocad(ByVal subDE As DBDictionaryEntry, ByRef fld As FullLayerData, _
            End Sub
    In the ReadLayerDataFromAutocad(), you change the properties of NewFLD for each LayerTableRecord in the LayerTable (and start a new Transaction which is unusefull as this method from within the transaction opened in the calling method).
    Gilles Chanteau
    New Member
    12-06-2012 08:25 AM in reply to: _gile
    using a STRUCTURE did the trick. I really don't understand why, but I will hopefully someday ( I am a newbie after all).
    thanks for the helps.
    *Expert Elite*
    12-06-2012 09:30 AM in reply to: ssomick
    Have a look here and/or google for "Value type vs Reference type".
    You can also run this little console application which is quite self explanatory:
        class RefType
            public string Name;
            public RefType(string name)
                Name = name;
        struct ValType
            public string Name;
            public ValType(string name)
                Name = name;
        class Program
            static void Main()
                ValType val1 = new ValType("val1");
                ValType val2 = val1;
                RefType ref1 = new RefType("ref1");
                RefType ref2 = ref1;
                val2.Name = "val2";
                ref2.Name = "ref2";
                Console.WriteLine(val1.Name); // prints: "val1"
                Console.WriteLine(val2.Name); // prints: "val2"
                Console.WriteLine(ref1.Name); // prints: "ref2"
                Console.WriteLine(ref2.Name); // prints: "ref2"
    Gilles Chanteau
