• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    Accepted Solution
    vb.net external open cad drawing
    720 Views, 10 Replies
    04-18-2012 03:50 PM
    First off, I have working code for opening a cad drawing from an external program.  That is perfect.
    What I'm at a loss for is how can I force a drawing that is NOT readonly to open as readonly from outside cad.    I know it's possible within cad, but that doesn't help me.
    Can anyone help me out here?
    Please use plain text.
    *Expert Elite*
    Re: vb.net external open cad drawing
    04-19-2012 06:51 AM in reply to: C_Witt
    How does your external program open a drawing? Without seeing your perfectly working code, I assume it automates AutoCAD via COM API AcadDocuments.Open() method (that is the drawing is still opened in AUTOCAD!)
    This method has 2 optional argument to specify if the drawing to be opened as READONLY, and specify a PASSWORD if the drawing is password-protected:
    AcadDocuments.Open "C:\....\mydrawing.dwg", True
    opens a drawing as read-only.
    Active Contributor
    04-19-2012 08:11 AM in reply to: C_Witt
    Actually, no.  I'm using this to open drawings in cad..
    System.Diagnostics.Process.Start(dwgpath)
    Sounds like i should be doing the other way..   Is there some place I can get a look at working examples?
    *Expert Elite*
    chiefbraincloud
    04-19-2012 10:06 AM in reply to: C_Witt
    I have not tried it , but without rewriting all of your existing code, I believe you could just set the ReadOnly Attribute on the file.
    Active Contributor
    04-19-2012 10:10 AM in reply to: C_Witt
    Not really an option (mainly because I still want the file to be editable at other times).
    *Expert Elite*
    chiefbraincloud
    04-19-2012 10:42 AM in reply to: C_Witt
    So Toggle the Attribute before opening, and toggle it back after closing.  I assumed that went without saying.
    *Expert Elite*
    chiefbraincloud
    04-23-2012 11:20 PM in reply to: C_Witt
    I didn't mean my last comment to be condescending, and I agree with Norman, that if you use the built-in COM mechanisms to open a drawing, there is a built-in way to open them read-only, but I just thought I would try to provide an alternative way, that did not require a significant change in your existing code.
    I will admit, my suggestion requires that the users of your program have (probably a network based) permission to alter the read/write access to the file in question.  At my company, that problem could come into question under certain circumstances, but not usually when dealing with drawings.
    Active Contributor
    04-24-2012 08:15 AM in reply to: C_Witt
    It's alright, everyone should let there inner Tony T out a few times.   :smileyhappy:
    I had briefly thought of doing it that way, but wasn't able to find a way of doing it.   I've since gone the COM route.  Works great (after several google searches and code corrections).
    *Expert Elite*
    Hallex
    04-24-2012 11:34 AM in reply to: C_Witt
    Would be interesting to show a result of your code,
    Oleg
    _____________________________________
    C6309D9E0751D165D0934D0621DFF27919
    Active Contributor
    04-24-2012 11:41 AM in reply to: C_Witt
    Not much to it, but here you go.  (though for some reason cad crashes if it's used to many times in one session... (5+ i've found))
    Used with vanilla 2011
    Public Sub Open_DWG ()
            Dim ACAD As Object
            Dim MyAcadPath As String = "dwgpath"
            Dim bReadOnly As Boolean = True
            On Error Resume Next
            ACAD = GetObject(, "autocad.Application")
            If Err.Number <> 0 Then
                Err.Clear()
                ACAD = CreateObject("autocad.Application")
                    MessageBox.Show("Failed to start", MessageBoxButtons.OK, MessageBoxIcon.Information)
                    GoTo EndOpen
            'ACAD.Visible = True
            Err.Clear()
            Dim NewFile As Object = ACAD.Documents.Open(MyAcadPath, bReadOnly)
                MessageBox.Show("Failed to open", MessageBoxButtons.OK, MessageBoxIcon.Information)
    EndOpen:
            ACAD = Nothing
            NewFile = Nothing
        End Sub
