.NET
Active Contributor
C_Witt
Message 1 of 11 (1,802 Views)
vb.net external open cad drawing
1802 Views, 10 Replies
04-18-2012 03:50 PM
First off, I have working code for opening a cad drawing from an external program.  That is perfect.
What I'm at a loss for is how can I force a drawing that is NOT readonly to open as readonly from outside cad.    I know it's possible within cad, but that doesn't help me.
Can anyone help me out here?
norman.yuan
Message 2 of 11 (1,775 Views)
Re: vb.net external open cad drawing
04-19-2012 06:51 AM in reply to: C_Witt
How does your external program open a drawing? Without seeing your perfectly working code, I assume it automates AutoCAD via COM API AcadDocuments.Open() method (that is the drawing is still opened in AUTOCAD!)
This method has 2 optional argument to specify if the drawing to be opened as READONLY, and specify a PASSWORD if the drawing is password-protected:
AcadDocuments.Open "C:\....\mydrawing.dwg", True
opens a drawing as read-only.
Active Contributor
C_Witt
Message 3 of 11 (1,770 Views)
04-19-2012 08:11 AM in reply to: C_Witt
Actually, no.  I'm using this to open drawings in cad..
System.Diagnostics.Process.Start(dwgpath)
Sounds like i should be doing the other way..   Is there some place I can get a look at working examples?
chiefbraincloud
Message 4 of 11 (1,755 Views)
04-19-2012 10:06 AM in reply to: C_Witt
I have not tried it , but without rewriting all of your existing code, I believe you could just set the ReadOnly Attribute on the file.
Active Contributor
C_Witt
Message 5 of 11 (1,753 Views)
04-19-2012 10:10 AM in reply to: C_Witt
Not really an option (mainly because I still want the file to be editable at other times).
chiefbraincloud
Message 6 of 11 (1,749 Views)
04-19-2012 10:42 AM in reply to: C_Witt
So Toggle the Attribute before opening, and toggle it back after closing.  I assumed that went without saying.
chiefbraincloud
Message 7 of 11 (1,715 Views)
04-23-2012 11:20 PM in reply to: C_Witt
I didn't mean my last comment to be condescending, and I agree with Norman, that if you use the built-in COM mechanisms to open a drawing, there is a built-in way to open them read-only, but I just thought I would try to provide an alternative way, that did not require a significant change in your existing code.
I will admit, my suggestion requires that the users of your program have (probably a network based) permission to alter the read/write access to the file in question.  At my company, that problem could come into question under certain circumstances, but not usually when dealing with drawings.
Active Contributor
C_Witt
Message 8 of 11 (1,696 Views)
04-24-2012 08:15 AM in reply to: C_Witt
It's alright, everyone should let there inner Tony T out a few times.   :smileyhappy:
I had briefly thought of doing it that way, but wasn't able to find a way of doing it.   I've since gone the COM route.  Works great (after several google searches and code corrections).
Hallex
Message 9 of 11 (1,683 Views)
04-24-2012 11:34 AM in reply to: C_Witt
Would be interesting to show a result of your code,
Oleg
Active Contributor
C_Witt
Message 10 of 11 (1,680 Views)
04-24-2012 11:41 AM in reply to: C_Witt
Not much to it, but here you go.  (though for some reason cad crashes if it's used to many times in one session... (5+ i've found))
Used with vanilla 2011
Public Sub Open_DWG ()
        Dim ACAD As Object
        Dim MyAcadPath As String = "dwgpath"
        Dim bReadOnly As Boolean = True
        On Error Resume Next
        ACAD = GetObject(, "autocad.Application")
        If Err.Number <> 0 Then
            Err.Clear()
            ACAD = CreateObject("autocad.Application")
                MessageBox.Show("Failed to start", MessageBoxButtons.OK, MessageBoxIcon.Information)
                GoTo EndOpen
            End If
        End If
        'ACAD.Visible = True
        Err.Clear()
        Dim NewFile As Object = ACAD.Documents.Open(MyAcadPath, bReadOnly)
            MessageBox.Show("Failed to open", MessageBoxButtons.OK, MessageBoxIcon.Information)
        End If
EndOpen:
        ACAD = Nothing
        NewFile = Nothing
    End Sub
You are not logged in.
Ask the Community
