.NET
two string are the same, but vb.net says they are not. what could be wrong?
4 REPLIES 4
sdren
312 Views, 4 Replies
i have two string that are the same, but vb.net says they are not. what could be wrong?
here is my except of the codes
Dim Blk As String = ""
Dim MyBlks() As String
some codes here
Dim txtFields() As String
txtLine = myFSR1.ReadLine
txtFields = txtLine.Split(",")
MyBlks = New String() {txtFields(0) , txtFields(2) , txtFields(3) , txtFields(4) }
some codes here
Blk = MyBlks(0)
some codes here
MsgBox Blk
If Blk= "doors1" Then InstallDoors1 Else InstallDoorsOther
the MsgBox displays the value of "doors1", but it does not InstallDoors1.
when i do PrintLine(myFn, Blk & "," & "doors1") it shows like below with a difference of "quotes"
"doors1",doors1
how do solve this difference? Edited by: sdren on Oct 30, 2009 7:35 PM
4 REPLIES 4
t.willey
in reply to: sdren
You might need to look at how the string class has overridden the ' = ' operator. On a side note, is it supposed to be ' == ' instead? The single ' = ' means you are trying to assign a variable to something. If that doesn't help, then maybe you can look at the string method ' Compare '.
_gile
in reply to: sdren
Hi Tim
The '==' is a C# operator.
It seems to me the VB '=' operator is used both to assign or to compare (but I don't know much about VB).
sdren,
Try:
Blk = txtFields(0) Edited by: _gile on Oct 30, 2009 11:03 PM
Gilles Chanteau
GileCAD
GitHub
in reply to: sdren
Watch for non standard characters that might not show up in the watch
window. I've seen Chr(10) at the beginning of strings causing brief
confusion. If in doubt loop through each and debug.print the asc code.
Terry
in reply to: sdren
Tim, there is no '==' in VB.NET.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6281473@discussion.autodesk.com...
”Boost
