.NET
transient line with dist command
4 REPLIES 4
joantopo
531 Views, 4 Replies
Hi, I have my own "dist" command.
I pick 2 points and I show it in command line(by prompt).
However, I would like to show the line (graphicsInterface.Transient) during the process. When I pick the first point and finally pick the second point exactly as "dist" command of AutoCAD.
Thanks in advance.
Regards.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
4 REPLIES 4
Jeff_M
in reply to: joantopo
Both the PromptPointOptions and PromptDistanceOptions have the properties "BasePoint", "UseBasePoint", & "UseDashedLine". This is what you use to get that rubberband line.
_gile
Look at the PromptPointOptions.BasePoint and PromptPointOptions.UseBasePoint properties.
Here's a little sample:
        [CommandMethod("Dist")]
        public void GetdDstance()
            Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
            PromptPointOptions opts = new PromptPointOptions("\nSpecify the first point: ");
            PromptPointResult reslt = ed.GetPoint(opts);
            if (reslt.Status == PromptStatus.OK)
                Point3d p1 = reslt.Value;
                opts.Message = "\nSpecify the second point: ";
                opts.BasePoint = p1;
                opts.UseBasePoint = true;
                if (reslt.Status != PromptStatus.OK)
                    Point3d p2 = reslt.Value;
                    ed.WriteMessage("\nDistance: " + Converter.DistanceToString(p1.DistanceTo(p2)));
Gilles Chanteau
GileCAD
GitHub
joantopo
in reply to: _gile
Is this:
http://spiderinnet1.typepad.com/blog/2012/03/autocad-net-entityjig-jig-line-by-start-and-end-points....
But I don´t want to use a specific class;
I want to jig the temporary line until click the second point.
joantopo
Yes.
It is ".UseBasePoint".
Thanks.
”Boost
