.NET
transfert project 2010 to 2014 - Command synchro not working
2 REPLIES 2
AubelecBE
604 Views, 2 Replies
hello, i have a vb.net prog :
1 - create a bloc with 2 attribut
2 - insert the bloc
3 - insert field in the attribut
4 - regen for regen the attribut with the good text (name of dwg and name of one xref)
5 - check the dim of the bloc
6 - add in the blockDef, a polyline
7 - end
in acad 2010 it is work fine but not in 2014. the etap 4 not working
here the code in the sub (etap 4)
 GestionAUTOCAD.LigneCommandeImmediate("_regen")
and here the function code in my gestionAutocad.vb :
    '**  Fonction Lancement d'une commande Synchrone sur la ligne         **
    '**   de commande d'Autocad                                           **
    '** ENTREE (exemple)                                                  **
    '**   Tracé une ligne :
    '**     CommandeSync("_.line", New Point3d(10.0, 20.0, 0.0), New Point3d(80.0, 50.0, 0.0), "")
    '**   Freeze du calque 0
    '**     CommandeSync("_.vplayer", "_freeze", "0", "_select", "\", "", "")
    '** Note:
    '**   - an empty string ("") means a validation (Enter)
    '**   - an anti-slash ("\" with VB or "\\" with C#) means a pause for user input.
    '**   - Texte : Le texte à afficher                                   **
    '** with A2013, replace "acad.exe" with "accore.dll" in the DllImport attribute arguments.
#If _AcadVer_ = 2010 Then
    <System.Security.SuppressUnmanagedCodeSecurity()> _
        <System.Runtime.InteropServices.DllImport("acad.exe", _
              EntryPoint:="acedCmd", _
              CharSet:=System.Runtime.InteropServices.CharSet.Unicode, _
              CallingConvention:=System.Runtime.InteropServices.CallingConvention.Cdecl)> _
    Private Function acedCmd(ByVal resbuf As IntPtr) As Integer
    End Function
#ElseIf _AcadVer_ = 2014 Then
        <System.Runtime.InteropServices.DllImport("accore.dll", _
    End Function
#End If
    '''<summary>
    ''' Call an AutoCAD command (runs synchronously).
    ''' </summary>
    ''' <param name="args">The command name followed by command inputs.</param>
    Public Sub LigneCommandeImmediate(ByVal ParamArray args As Object())
        Dim resbuf As New ResultBuffer()
        For Each obj As Object In args
            Select Case obj.GetType().Name
                Case "String"
                    resbuf.Add(New TypedValue(CInt(Autodesk.AutoCAD.Runtime.LispDataType.Text), obj))
                    Exit Select
                Case "Int16"
                    resbuf.Add(New TypedValue(CInt(Autodesk.AutoCAD.Runtime.LispDataType.Int16), obj))
                    Exit Select
                Case "Int32"
                    resbuf.Add(New TypedValue(CInt(Autodesk.AutoCAD.Runtime.LispDataType.Int32), obj))
                    Exit Select
                Case "Double"
                    resbuf.Add(New TypedValue(CInt(Autodesk.AutoCAD.Runtime.LispDataType.[Double]), obj))
                    Exit Select
                Case "Point2d"
                    resbuf.Add(New TypedValue(CInt(Autodesk.AutoCAD.Runtime.LispDataType.Point2d), obj))
                    Exit Select
                Case "Point3d"
                    resbuf.Add(New TypedValue(CInt(Autodesk.AutoCAD.Runtime.LispDataType.Point3d), obj))
                    Exit Select
                Case "ObjectId"
                    resbuf.Add(New TypedValue(CInt(Autodesk.AutoCAD.Runtime.LispDataType.ObjectId), obj))
                    Exit Select
                Case "ObjectId[]"
                    For Each id As ObjectId In DirectCast(obj, ObjectId())
                        resbuf.Add(New TypedValue(CInt(Autodesk.AutoCAD.Runtime.LispDataType.ObjectId), id))
                    Next
                    Exit Select
                Case "ObjectIdCollection"
                    For Each id As ObjectId In DirectCast(obj, ObjectIdCollection)
                    Next
                    Exit Select
                Case "SelectionSetDelayMarshalled", "SelectionSetFullyMarshalled"
                    resbuf.Add(New TypedValue(CInt(Autodesk.AutoCAD.Runtime.LispDataType.SelectionSet), obj))
                    Exit Select
                Case Else
                    Throw New InvalidOperationException("Unsupported type in Command() method")
            End Select
        Next
        acedCmd(resbuf.UnmanagedObject)
    End Sub
why it is not working in acad 2014 ?
so i can replace the function with a new part issu from the new version of acad 2014 ?
thanks
2 REPLIES 2
Hallex
in reply to: AubelecBE
Just on the quick glance: is this line right:
Case "ObjectId[]" in vb.net?
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
AubelecBE
in reply to: Hallex
yes. but i send a string so it is not the bug here.
”Boost
