.NET
toolbar icon use resource file
2 REPLIES 2
wesbird
275 Views, 2 Replies
Is there any I can use image in my resouce file as toolbar icon. I am not sure if this, SetBitmaps(string, string), work with ResourceManager? Has anybody tried this before?
Is this possible?
Thank you
Merry Christmas
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
smcclure
in reply to: wesbird
It is kind of possible in a kludgy way... I solve this by writing the image out at runtime and assigning it to the toolbar...
[code]
Dim lgBitmap As System.Drawing.Bitmap = TryCast(My.Resources.ResourceManager.GetObject(attr.LargeImage), System.Drawing.Bitmap)
Dim smBitmap As System.Drawing.Bitmap = TryCast(My.Resources.ResourceManager.GetObject(attr.SmallImage), System.Drawing.Bitmap)
CreateToolbarButton(toolbar, toolbar.Count, attr.Name, attr.Description, attr.Command, lgBitmap, smBitmap)
Public Sub CreateToolbarButton(ByVal toolbar As Autodesk.AutoCAD.Interop.AcadToolbar, ByVal index As Integer, ByVal name As String, ByVal desc As String, ByVal command As String, ByVal lgImg As Bitmap, ByVal smImg As Bitmap)
Dim button As Autodesk.AutoCAD.Interop.AcadToolbarItem = toolbar.AddToolbarButton(index, name, desc, "\x1b\x1b_" & command & "\n")
Dim lgImagePath As String = System.IO.Path.Combine(My.Application.Info.DirectoryPath, lgImg.GetHashCode().ToString() & ".bmp")
Dim smImagePath As String = System.IO.Path.Combine(My.Application.Info.DirectoryPath, smImg.GetHashCode().ToString() & ".bmp")
If lgImg IsNot Nothing Then
If Not System.IO.File.Exists(lgImagePath) Then lgImg.Save(lgImagePath, System.Drawing.Imaging.ImageFormat.Bmp)
Else
My.Application.Log.WriteEntry("Could not find large toolbar image for toolbar button: " & name, TraceEventType.Warning)
lgImagePath = String.Empty
End If
If smImg IsNot Nothing Then
If Not System.IO.File.Exists(smImagePath) Then smImg.Save(smImagePath, System.Drawing.Imaging.ImageFormat.Bmp)
Else
My.Application.Log.WriteEntry("Could not find small toolbar image for toolbar button: " & name, TraceEventType.Warning)
smImagePath = String.Empty
End If
button.SetBitmaps(smImagePath, lgImagePath)
End Sub
[/code]
wesbird
Thank you, I will try it.
Wes
”Boost
