.NET
Valued Contributor
mario.rosenbohm
Message 1 of 5 (190 Views)
there is an event at the show of multiselect ribbontab?
190 Views, 4 Replies
07-09-2012 03:34 AM
there is an event at the show of multiselect ribbontab on Civil3D?
regards Mario
Distinguished Contributor
VB_Autocad_guy
Message 2 of 5 (160 Views)
Re: there is an event at the show of multiselect ribbontab?
07-17-2012 08:38 AM in reply to: mario.rosenbohm
Can you give us some more information?
At the show? Do you mean when the Ribbon Tab is loaded?
Valued Contributor
mario.rosenbohm
Message 3 of 5 (146 Views)
07-17-2012 11:31 PM in reply to: VB_Autocad_guy
I programming a Tool to set elevation from Selected objects to input Value, parsing layername or flatten to input value.
The reference for elevation (z-axis=0.0)  is possible world or current ucs. To visible the current reference i change
the icon from ribbonbutton. That all works fine. To change  the icon i use the "Autodesk.Windows.RibbonButton"  because the "Autodesk.AutoCAD.Customization.RibbonButton" has no "Image and LargeImage" property.
In Civil3D activate on multiple objecttype-selection a new ribbon tab from 'state-kontextsensitive-multiselect-tab' (sorry i have only a german civil). On cui i have bound the ribbongroup to this tabs. If the tab is shown i must change the 'reference-ribbonbutton-icon'.
A solutions approach might also 'how do I get one from a  "Autodesk.AutoCAD.Customization.RibbonButton" a "Autodesk.Windows.RibbonButton"'?
Or even this.
regards Mario
VB_Autocad_guy
Message 4 of 5 (131 Views)
07-18-2012 12:35 PM in reply to: mario.rosenbohm
Sorry,
I don't understand your question very well.
Maybe use the Copy or Clone method to copy it to the Other type of object? Just taking a guess.
I took a look at the RibbonButton Classes in
Autodesk.Windows & Autodesk.AutoCAD.Customization.
You may want to try asking this question in the ARX development area.
(http://forums.autodesk.com/t5/Autodesk-ObjectARX/bd-p/34)
But maybe this might help.
Sorry, I know not much help. :smileyfrustrated:
Good luck!
ADN Support Specialist
Balaji_Ram
Message 5 of 5 (114 Views)
07-27-2012 08:20 AM in reply to: mario.rosenbohm
Hi Mario,
From what I understand, are you looking for an event that will let you know that the Ribbon is initialized.
Have you tried using the "Autodesk.Windows.ComponentManager.ItemInitialized" event ?
In the event handler, you can check if the ribbon is not null and then you know for sure that the Ribbon is ready.
void ComponentManager_ItemInitialized(object sender, RibbonItemEventArgs e)
    if (Autodesk.Windows.ComponentManager.Ribbon != null)
         // Ribbon is ready...
Balaji
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Ask the Community
