.NET
text in a rectangle
1 REPLY 1
381 Views, 1 Reply
text in a rectangle
Hi all,
i'm writing an overrule that write some text into a region, but then the text is too long it edged out.
Is there a way to keep the text into the rectangle, with multiline or setting the boundaries or something else?
Many Thanks.d
Tags (2)
1 REPLY 1
chiefbraincloud
The Justifications with "FIT" at the end (BottomFit, TopFit, etc...) will cause the text to remain a fixed overall width.
That can make the text look really funny, or be nearly unreadable, if the string is too short or too long, so may want to include some kind of check in your code and only use Fit if your test says the string is a little too long.
You can also use MText, which is multiline, but it will only break the lines at spaces or carriage returns.
”Boost
