.NET
speaking of cui files
6 REPLIES 6
614 Views, 6 Replies
Is there any way in .Net to enable/disable menu items?
In Arx I used the menucmd function to do this but don's
see anything like that in the .Net api's.
Perry
6 REPLIES 6
What about use of acedMenuCmd() with P/Invoke in .NET-application?
I haven't tried that Alexander, I'm not really a COM kinda guy.
May have to though!
Try this code:
[code]
using System;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(ClassLibrary.Class))]
namespace ClassLibrary
public class Class
class MenuCmd
static int AcadVersion = Autodesk.AutoCAD.ApplicationServices.Application.Version.Major;
// For AutoCAD 2006:
[System.Security.SuppressUnmanagedCodeSecurity]
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Ansi, EntryPoint = "acedMenuCmd")]
extern private static int acedMenuCmd16(string cmd);
// For AutoCAD 2007:
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode, EntryPoint = "acedMenuCmd")]
extern private static int acedMenuCmd17(string cmd);
public static int acedMenuCmd(string cmd)
switch (AcadVersion)
case 16: return acedMenuCmd16 (cmd);
case 17: return acedMenuCmd17 (cmd);
return -1;
[CommandMethod("TESTMENU")]
static public void test() // This method can have any name
MenuCmd.acedMenuCmd("p0=ACAD.OSNAP");
MenuCmd.acedMenuCmd("p0=*");
[/code]
> Try this code:
> [code]
> using System;
> public class Class
> class MenuCmd
> return -1;
> [/code]
Hey thanks Alexander :0
I will try this as soon as I can.
Looks like a good example for me to learn from also.
> Try this code:
> [code]
> using System;
> public class Class
> class MenuCmd
> return -1;
> [/code]
Thanks Alexander
what you provided worked like a charm. Took me awhile though to figure
out how to "grey" a menu item. Not used to cui files yet, was using the
wrong "ID's". Works good now though 🙂
Can I access any Acad command the same way?
Perry
Yes you can: http://discussion.autodesk.com/thread.jspa?messageID=4852689
”Boost
