.NET
show a picture in a picturebox control, but the previewicon is so small
10 REPLIES 10
Message 1 of 11
swaywood
908 Views, 10 Replies
Hi,all:
     I want to generate the images for the blocks, I found a method of blcitablerecord, but the image is too small, and can not show out clearly.
Bitmap preview = btr.PreviewIcon;
    you know in autocad there is a MSLIDE command, can make a .sld file which can show out clearly in a lisp programe, but in .net winform how to show the image clearly? or other method to solve it?
10 REPLIES 10
Message 2 of 11
swaywood
in reply to: swaywood
Message 3 of 11
hgasty1001
See :Preview Images
By the way, that screen grab looks quite old.
Gaston Nunez
Message 4 of 11
swaywood
in reply to: hgasty1001
Hi,Gasty:
    thank you for your information. I tried Kean's code, but get a error, can not found the method 'CMLContentSearchPreviews'.
    by the way, what's the new screen grab tool you use?
regards
swaywood
Message 5 of 11
swaywood
can any body help me?
I can not found the method of 'CMLContentSearchPreviews' in autocad2013 Autodesk.AutoCAD.Windows.Data namespace.
the following is kean's blog address.
http://through-the-interface.typepad.com/through_the_interface/2013/11/generating-larger-preview-ima...
Message 6 of 11
Jeff_M
Looks like that Class was added to the 2014 product, so you won't see it in 2013.
Jeff_M, also a frequent Swamper
Message 7 of 11
swaywood
in reply to: Jeff_M
hi,jeff:
Message 8 of 11
swaywood
Hi,jeff:
do you know autocad2014 match what VS and framework .net version?
it seem's .net 4.0 can not import 2014 version acmgd.dll for me.
Message 9 of 11
Jeff_M
I used VS2010, until just recently, with AutoCAD 2014. .NET 4.0
Message 10 of 11
hgasty1001
I'm using VS 2013 now, but i don't remember problems with Autocad 2014 and .net 4.0 in VS 2010, are you sure you have the right SDK , reference from the include folder and set copy to local false?
Gaston Nunez
Message 11 of 11
swaywood
Hi,Gaston Nunez and Jeff:
Thank you so much!
I got the bigger and clearer pictures in autocad 2014.
but the dll can not netload in autocad 2013.
Smiley LOL
”Boost
