.NET
Distinguished Contributor spu
spu
Message 1 of 3 (308 Views)
save all open drawings
308 Views, 2 Replies
08-09-2011 01:49 AM
I tried the following method to save all drawing currently open. It always fire fill access arror, whereas AutoCAD can save the file wihthout any issue. Here I am checking for drawings that not even saved once and ask the user to take action for those files.
 try
                DocumentCollection docs = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
                foreach (Document doc in docs)
                    string dname = doc.Name;
                    string s = doc.Name.Substring(doc.Name.LastIndexOf('\\') + 1);
                    if (s != doc.Name)  //checking for additional path
                       doc.Database.SaveAs(dname, true, DwgVersion.Current,doc.Database.SecurityParameters);
                    else
                        System.Windows.Forms.MessageBox.Show("Please save " + doc.Name + " manualy!!!!");
            catch (System.Exception ee)
                System.Windows.Forms.MessageBox.Show("Exception: " + ee.Message);
Shijith
Active Contributor
jamierobertson1
Message 2 of 3 (284 Views)
Re: save all open drawings
08-09-2011 10:05 AM in reply to: spu
For some reason I have had some problems saving to some acad versions. Try changing this bit to see if this works:
doc.Database.SaveAs(dname, DwgVersion.AC1800)
spu
Message 3 of 3 (263 Views)
08-09-2011 09:38 PM in reply to: jamierobertson1
Thanks for the reply.
I tried it, it also behaves the same.....It gives the following AutoCAD message and exception.
Autocad Message: Error writing / closing file.
Exception: efileAccessErr
But the same drawing Autocad saves with out any trouble.
Shijith
You are not logged in.
Announcements
Need installation help?
Ask the Community
