.NET
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
recieving run time error for acmgd.dll
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
"Could not load file or assembly 'acmgd, Version=17.0.54.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified."
This is the error i recieve, i've already referenced the dll from local installed folder, and made local copy as false. but also i recieve this error... please help me in this i need to proceed with this rectification
Re: recieving run time error for acmgd.dll
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
questions to that:
- what AutoCAD-version do you drive?
- when did you receive the error .... when doing _NETLOAD or anywhere else?
- have you looked into your bin-output-directory if you have no AC*MGD*.dll sitting around? Because if you had set "copy local" to yes before it may have been copied and setting back to "no" the copy may not be removed automatically.
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
autocad2007
wen call this class during run time.. i recieve the error at the calling line...
i've tried by removing the dll form project directory also
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
And when you load the project manually with _NETLOAD you don't get the error?
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
sorry i dont get wat is _NETLOAD???
I'm new to this VB.net....
i've builded the project manually i didnt get any error or warnings...
is this is objectarx concept or vb.net autocad api
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
_NETLOAD is a command built into AutoCAD that lets you load your dotNET-DLL into AutoCAD (so the init is done and defined commands within your DLL are now available for this AutoCAD session).
Not knowing any project structure you use I'll start with the standard case using vb.NET for AutoCAD:
- you have a DLL-project
- within this project you have some custom-commands for AutoCAD defined
- within this project you may have some initialization included
- you compile the project so you get a DLL-file
- you start AutoCAD
- you start command _NETLOAD and point to this DLL-file to get loaded
- if you have some init-stuff ==> it's now executed
- the commands you developed are now available within this AutoCAD session.
If you haven't used _NETLOAD ever (and you have not set some registry items to get the DLL loaded automatically) you should start describing how your project works (should work).
When you don't get your DLL loaded (either by _NETLOAD or by any reg-setting) I can't imagine how do you get it running?
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i'm creating a seperate windowsapplication with a form and oather stuffs. will be getting inputs from the user to get drawings in autocad.
for time being i just had a button and in the click event i've called the sub routine from a class containing
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Public Class Class1
Public Shared Sub NewClass()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim tAcadDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim tTrAct As Transaction = Nothing
Using myTrans As Transaction = tAcadDoc.TransactionManager.StartTransaction
Dim tBlTab As BlockTable = CType(tTrAct.GetObject(tAcadDoc.Database.BlockTabl
Dim tModSp As BlockTableRecord = CType(tTrAct.GetObject(tBlTab(BlockTableRecord.Mod
Dim tModSpCOM As AcadModelSpace = CType(tModSp.AcadObject, AcadModelSpace)
For Each myObjId As ObjectId In tModSpCOM
Dim myEnt As Entity = CType(myObjId.GetObject(OpenMode.ForRead), Entity)
Select Case UCase(myEnt.PlotStyleName)
Case "ACDBLINE"
End Select
Next
End Using
End Sub
End Class
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you mean you are creating an EXE?
If so: You can't use the MGD-library from outside of AutoCAD and so you won't get the managed assemblies loaded.
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
so u understand my needs right???
guide me good book for autocad api, that gives basic knowledge about this cad api's all those things....
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not sure if I do. ;(
Sorry, I have none. But you should be able to search with Google (like >>>this<<<), then you may find some for your language, some in english, you can chose then.
- alfred -
Alfred NESWADBA
