.NET
Valued Contributor
scarta
Message 1 of 4 (495 Views)
rebuild to 2013 .net
495 Views, 3 Replies
05-16-2012 07:57 AM
Hi, I have to rebuil a vb.net dll (2012) for use it with AutoCAD1013
I use visual studio Express 2010 and i receive the error "open is not a member of  'Autodesk.AutoCAD.ApplicationServices.DocumentCollection' on this line:
myDWG = acDocMgr.Open(cartOrigine,False)
i have changed reference to 2013 and add a ref to accoremgd
someone can help me?
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Colors
Imports System
Imports System.Windows.Forms
Imports System.Math
'formati saveas
'MC0.0 - DWG from Rel. 1.1
'AC1.2 - DWG from Rel. 1.2
'AC1.4 - DWG from Rel. 1.4
'AC1.50 - DWG from Rel. 2.0
'AC2.10 - DWG from Rel. 2.10
'AC1002 - DWG from Rel. 2.5
'AC1003 - DWG from Rel. 2.6
'AC1004 - DWG from Rel.9
'AC1006 - DWG from Rel.10
'AC1009 - DWG from Rel.11/12 (or LT R1/R2)
'AC1012 - DWG from Rel.13 (or LT95)
'AC1014 - DWG from Rel.14, 14.01 (or LT97/LT98)
'AC1015 - DWG from AutoCAD 2000/2000i/2002 (or LT, Map or relative Desktop version)
'AC1018 - DWG from AutoCAD 2004/2005/2006 (or other product in the "2004", "2005" or "2006" family)
'AC1021 - DWG from AutoCAD 2007/2008/2009 (or other product of the "2007", "2008" and "2009" families)
'AC1024 - DWG from AutoCAD 2010 (or other product of the "2010" family)
Public
ClassCart_Auto
CommandMethod("cartauto", CommandFlags.Session)> _
PublicSubcartauto()
Dim strPath AsStringDim strPathDest AsStringDim strNomeFile AsStringDim strTargetFile AsStringDim cartOrigine AsStringDim intpointer AsIntegerDim pos_Pipe(1) AsObjectDim Titolo(5) AsStringDim max_digit, contrTitolo, contrTitoloMax AsIntegerDim myDB As DatabaseServices.DatabaseDim myDWG As ApplicationServices.DocumentDim myEd As EditorInput.EditorDim myPFR As EditorInput.PromptFileNameResultDim myPFO AsNew EditorInput.PromptOpenFileOptions("Select a file:")
Dim strNomeBlocco AsString'= "blocco_attributo"Dim nomeSpazio AsString
strPath = Autodesk.AutoCAD.ApplicationServices.
Application.GetSystemVariable("dwgprefix")
' carico il file delle impostazioni
myDWG = ApplicationServices.
Application.DocumentManager.MdiActiveDocument
myDB = myDWG.Database
myEd = myDWG.Editor
myPFO.DialogCaption =
"Seleziona File Impostazioni..."
myPFO.InitialDirectory = strPath
myPFO.Filter =
"File INI|*.ini"
myPFR = myEd.GetFileNameForOpen(myPFO)
SelectCasemyPFR.Status
Case EditorInput.PromptStatus.Cancel
MsgBox(
"User Cancelled.")
EndSelect
strNomeFile = myPFR.StringResult
Dim myFSW1 AsNew IO.StreamReader(strNomeFile)
Dim txtLine1 AsString'While myFSW1.EndOfStream = False
txtLine1 = myFSW1.ReadLine
cartOrigine = txtLine1
strPathDest = txtLine1
max_digit = Val(txtLine1)
contrTitolo = Val(txtLine1)
contrTitoloMax = Val(txtLine1)
strNomeBlocco = txtLine1
nomeSpazio = txtLine1
'End While
myFSW1.Close()
' carico il file elenco
myEd = myDWG.Editor
"Seleziona File Elenco..."
myPFO.Filter =
"File Testo|*.TXT"
MsgBox(
"User Cancelled.")
EndSelect
Dim myFSW AsNew IO.StreamReader(strNomeFile)
Dim txtLine AsStringDim acDocMgr AsDocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
Dim doc1 AsDocument
While myFSW.EndOfStream = False
txtLine = myFSW.ReadLine
If Left(txtLine, 1) = "|"Or txtLine.ToUpper = "FINE"ThenGoToa101
EndIf
myDWG = acDocMgr.Open(cartOrigine,False) ' apre il cartiglio di origine
arcticad
Message 2 of 4 (491 Views)
Re: rebuild to 2013 .net
05-16-2012 08:05 AM in reply to: scarta
http://forums.autodesk.com/t5/NET/Open-is-not-a-member-of-ApplicationServices-DocumentCollection/m-p...
(defun botsbuildbots() (botsbuildbots))
Valued Contributor
scarta
Message 3 of 4 (489 Views)
05-16-2012 08:24 AM in reply to: arcticad
thanks... I do not understand where I have to correct
i have changed Documentcollection with ocumentcollectionextension..but not wok
Dim acDocMgr As DocumentCollectionExtension
acDocMgr = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
Valued Contributor
scarta
Message 4 of 4 (482 Views)
05-16-2012 08:56 AM in reply to: arcticad
Now work!!
thanks
You are not logged in.
Ask the Community
