productkey replacement in dot net 4
Anyone know the replacement for the following property:
Autodesk.AutoCAD.Runtime.SystemObjects.DynamicLinker.ProductKey
J.
_gile
Have a look at the ObjectARX 2013\Docs\arxmgd.chm file: Migration Guide > .NET Migration Guide > Changed .NET API:
Autodesk.AutoCAD.DatabaseServices.HostApplicationServices.Current.UserRegistryProductRootKey
or
Autodesk.AutoCAD.DatabaseServices.HostApplicationServices.Current.MachineRegistryProductRootKey
Gilles Chanteau
GileCAD
GitHub
CADbloke
Really?
Because all I see in that section of the Docs is ...
Class
Declaration
Previous Declaration
AssocPersSubentityId
public static void CreateObjectAndDwgInFields(Database database, DwgFiler filer, ref AssocPersSubentityId createdPersSubentId);
static Acad::ErrorStatus createObjectAndDwgInFields(AcDbDwgFiler* pFiler, AcDbAssocPersSubentId*& pCreatedPersSubentId);
SymbolUtilityServices
public static string PreValidateSymbolName(string symbolName, [MarshalAs(UnmanagedType.U1)] bool preserveCase);
public static string PreValidateSymbolName([MarshalAs(UnmanagedType.U1)] bool preserveCase);
View
public Extents2d ViewportExtents;
public Extents2d ViewportD;
working on all sorts of things including www.tvCAD.tv & www.CADreplace.com
StephenPreston
You're looking in the Changed function list. Look in the Removed function list (which documents the functions to use instead).
Cheers,
Stephen Preston
Autodesk Developer Network
CADbloke
Ah, yes I did. I followed "Migration Guide > .NET Migration Guide > Changed .NET API:" from above.
Thanks.
