.NET
problem with user defined control
10 REPLIES 10
Message 1 of 11
781 Views, 10 Replies
Has anybody here ever created a user defined control and then used that
control on a form in the same project? Whenever I do this, for some reason
the form will not display in Design mode. I can view the code, and the
project runs successfully, but the Designer throws an exception and says
that there is a problem with the code (but doesn't say anything else about
the problem). If I build the project, start a NEW project and set a
reference to the first project, I can use the user defined control without
any problems. The error only happens if I try to use the control in the
same project where the control is defined.
Has anybody else seen this problem or know how to fix it? I am using VS.NET
7.0 (2002) without the service pack (for compatability reasons).
Jon
10 REPLIES 10
Message 2 of 11
KrishnaK
Hi Jon,
I have seen this problem with dockingPalette SDK sample. I thought I messed up VS generated code, which I could have because I was trying to add a custom combo box on the palette. I found a blog that talks about this - http://weblogs.asp.net/rweigelt/archive/2003/09/04/26262.aspx
I didn't try to fix this, so if you found a way, please let me know!
Krishna Kalvai
DevTech
Message 3 of 11
Hi Krishna,
Thanks for replying. That link provides some useful information. I think
the problem goes a little deeper than the solutions offered by that blog,
however. I don't believe the error is in my code - I think it has something
to do with the AutoCAD managed dll's. I did a little experimentation, and I
think I tracked down the problem (but not the solution). To reproduce this
issue reliably, do this:
Create a brand new VB class library project.
Create a blank form in this project
Create a user control in this project (but don't add or change any code)
Build the project.
Add the user control to the form.
Close the form and re-open it. It should open without a problem.
Close the form again.
Add a reference to acmgd.dll (2006)
Open the form again.
The designer throws an exception.
Remove the reference to acmgd.dll
Close the form and reopen it again.
Everything is back to normal.
If you'd prefer, I can submit a DHO ticket on this...
Jon
wrote in message news:4855100@discussion.autodesk.com...
Hi Jon,
Krishna Kalvai
DevTech
Message 4 of 11
KrishnaK
Jon,
I was able to reproduce the error - thanks for the steps. However I don't think this is an acad bug. It is a visual studio bug (haven't checked to see if this is fixed in VS 2003). If for example you set the "Copy Local" property of acmgd.dll to False you can see the form in design mode. I think VS wrongly looks at acmgd for some reason when it loads the UserControl. I found this problem is common among apps that derive their own forms. VS instantiates the controls in order to display them.
Krishna Kalvai
DevTech
Message 5 of 11
Excellent! Thank you so much for figuring this out - it was driving me
crazy!!
Jon
wrote in message news:4856154@discussion.autodesk.com...
Jon,
Krishna Kalvai
DevTech
Message 6 of 11
KrishnaK
Glad to be of help!
Krishna
Message 7 of 11
dickinson.fred
I tried your suggestion to set the "Copy Local" property of acmgd.dll to False (I also did it for acdbmgd.dll). When I try to add my user defined control to a form I get an error "Failed to load toolbox item 'conGetPoint'. It will be removed from the toolbox.".
I have narrowed down the problem to the following line in the user control "Dim cPoint As Geometry.Point3d". Without the line the control can be added, with the line I get the error.
I am using VS2005 and AutoCAD2008.
Your help would be appreciated.
Message 8 of 11
The problem is that your control is trying to create an
instance of an AutoCAD type inside of Visual Studio's
designer.
A designable-control cannot use types from AutoCAD's
assemblies in code that runs in the designer/IDE.
Without seeing your control's source, or the relevant
parts of it, I can't tell you how to resolve that.
You can use a test that tells if your control's code is
running in the designer, or in AutoCAD, by reading
the value of the DesignMode property (true means
that the control is instantiated in the designer).
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message
news:6397745@discussion.autodesk.com...
Message 9 of 11
dickinson.fred
Thanks. It's good to know that its a VS / AutoCAD issue.
Here is a stripped down version of the control code which resides in the same project as the form where I'm trying to insert the control. The error happens when I try to add the control to the form. I have a similar control for getting a distance but it uses a "Double" type. Maybe I can return the 3 coordinates back as 3 doubles by getting them individually from pPromptPointResult.Value.X, Y, Z.
The offending line is "Dim cMyPoint As Geometry.Point3d".
{code
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.EditorInput
Public Class conGetPointX
Public Property MYPoint() As Geometry.Point3d
Get
Return cMyPoint
End Get
Set(ByVal Value As Geometry.Point3d)
cMyPoint = Value
End Set
End Property
Private Sub PickBTN_Click( _
ByVal sender As System.Object, _
ByVal e As System.EventArgs _
) Handles PickBTN.Click
GetPoint()
XTXT.Text = cMyPoint.X
YTXT.Text = cMyPoint.Y
ZTXT.Text = cMyPoint.Z
End Sub
Private Sub GetPoint()
Dim pDrawing As ApplicationServices.Document
pDrawing = ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim pEditor As Editor
pEditor = pDrawing.Editor
Dim pPromptPointOptions As New EditorInput.PromptPointOptions("")
With pPromptPointOptions
.Message = vbCrLf & "Enter coordinates or select a point:"
.AllowArbitraryInput = False
.AllowNone = False
.UseDashedLine = True
End With
Dim pPromptPointResult As EditorInput.PromptPointResult = Nothing
pPromptPointResult = pEditor.GetPoint(pPromptPointOptions)
Select Case pPromptPointResult.Status
Case PromptStatus.OK
cMyPoint = pPromptPointResult.Value
End Select
End Sub
End Class
/code}
Message 10 of 11
That's not going to work as you have it.
Change your member variable and public
property to double(3) (array of 3 doubles).
You can still use Point3d in your class, but
not in code that executes in the IDE.
You should also apply these attributes to
the public MyPoint property:
[Browsable(false)]
[DesignerSerializationVisibility(DesignerSerializationVisibility.Hidden)]
You don't want that property to appear in
the Properties window in the designer, and
you don't want the designer to serialize its
value either, which is what both of the above
attributes will prevent.
wrote in message
news:6397891@discussion.autodesk.com...
Y, Z.
{code
Get
Return cMyPoint
End Get
cMyPoint = Value
End Set
End Property
GetPoint()
End Sub
pDrawing =
.AllowNone = False
End With
End Select
End Sub
End Class
/code}
Message 11 of 11
dickinson.fred
Taking the Point3D out of the IDE interface and using an array of doubles for the public property fixed the problem.
Thanks very much for your help.
”Boost
