.NET
problem with constructor
4 REPLIES 4
nklong
600 Views, 4 Replies
I want to inform user the name of command immediately when they netload my dll. I use the constructor like this way:
public class Control
        public Control()
            Editor acDoc = Application.DocumentManager.MdiActiveDocument.Editor;
            acDoc.WriteMessage("Type ABC to start");
        [CommandMethod("abc", CommandFlags.UsePickSet)]
        public void MyForm_start()
            MyForm fr = new MyForm();
            Application.ShowModalDialog(fr);
But it only write to command line when call abc command. Pls help!
4 REPLIES 4
Hallex
in reply to: nklong
Try use
Autodesk.AutoCAD.ApplicationServices.Application
instead of Application
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
nklong
in reply to: nklong
Thank you, but it's still not right. I need after user call 'netload' and select my dll file. it will show some information to autocad command line.
Thank again.
DiningPhilosopher
in reply to: nklong
The class that contains your command methods is not constructed until the first time one of the commands is used.
You have to use IExtensionApplication.Initialize() to display a message when your assembly is Netloaded.
nklong
in reply to: nklong
Thank you so much. I can do it already.
    public class Control : Autodesk.AutoCAD.Runtime.IExtensionApplication
        public void Initialize()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage("Type ABC to start.");
        public void Terminate()
            Console.WriteLine("Cleaning up...");
”Boost
