.NET
Valued Contributor
sanjaymann
Message 1 of 8 (306 Views)
nwcout
306 Views, 7 Replies
10-06-2013 09:14 PM
I know we can create navis file[.nwc] by using nwcout command but how do we create navis file [.nwc ] programatically.
Thanks & Regards
ADN Support Specialist
philippe.leefsma
Message 2 of 8 (266 Views)
Re: nwcout
10-08-2013 02:43 AM in reply to: sanjaymann
There is no API to export to .nwc format. You would need to programmatically send the nwcout command using Document.SendStringToExecute for example.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Valued Contributor
sanjaymann
Message 3 of 8 (261 Views)
Re: nwcout
10-08-2013 02:57 AM in reply to: philippe.leefsma
Ok. Got the point.I have used Document.SendStringToExecute with attsync :
Dim blname as String="Test"
Dim command As String = "_ATTSYNC Name " + blname + vbCr
doc.SendStringToExecute(command, True, False, False)
But I am unable to call NWCOUT I tried:
Dim path as String="c:\Test"
Dim command As String = "_NWCOUT Path " + path+ vbCr
philippe.leefsma
Message 4 of 8 (259 Views)
Re: nwcout
10-08-2013 03:05 AM in reply to: sanjaymann
Which version of AutoCAD are you using? Because in plain AutoCAD I can't see a NWCOUT command...
Philippe Leefsma
Valued Contributor
sanjaymann
Message 5 of 8 (252 Views)
Re: nwcout
10-08-2013 03:15 AM in reply to: philippe.leefsma
Autocad 2013
Valued Contributor
sanjaymann
Message 6 of 8 (249 Views)
Re: nwcout
10-08-2013 03:24 AM in reply to: philippe.leefsma
The following code prompts me for the path:
Dim dbt AsDatabase = Application.DocumentManager.MdiActiveDocument.Database
Dim doc2 AsDocument = Application.DocumentManager.MdiActiveDocument
Dim command AsString = "_NWCOUT " + "d:\w.nwc" + vbCr
 doc2.SendStringToExecute(command,True, False, False)
How do I manage to pass the file path to the command
philippe.leefsma
Message 7 of 8 (243 Views)
Re: nwcout
10-08-2013 04:10 AM in reply to: sanjaymann
This needs to be done as follow:
[DllImport("accore.dll", CharSet = CharSet.Unicode,
    CallingConvention = CallingConvention.Cdecl,
    EntryPoint = "acedCommandS")]
private static extern int acedCommandS(
    int type1,
    string str1,
    int type2,
    string str2,
    int end);
[CommandMethod("NwcOutNet")]
public void NwcOutNet()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    object filedia = Application.GetSystemVariable("FILEDIA");
    Application.SetSystemVariable("FILEDIA", 0);
    acedCommandS(5005, "_NWCOUT", 5005, "c:\\Temp\\test.nwc", 5000);
    Application.SetSystemVariable("FILEDIA", filedia);
Philippe Leefsma
Valued Contributor
sanjaymann
Message 8 of 8 (205 Views)
Re: nwcout
10-09-2013 01:22 AM in reply to: philippe.leefsma
Thanks. This worked like a charm:smileyhappy:
You are not logged in.
Ask the Community
