.NET
no implementation of get_Item in Type DBDictionary
3 REPLIES 3
478 Views, 3 Replies
after I made a reference to AcDbMgd.dll and AcMgD.dll from the ObjectARX 2011 SDK I've got this message:
The method "get_Item" in Type "Autodesk.AutoCAD.DatabaseServices.DBDictionary" of the assembly "acdbmgd, Version=18.1.0.0, Culture=neutral, PublicKeyToken=null" has no implementation
This is a translation from german to english because I got all messages in german. I hope it correct.
What must I do?
Regards Jürgen
3 REPLIES 3
adam.nagy
In your code are you trying to call DBDictionary.Item()?
You should use DBDictionary.GetAt() function instead.
I hope this helps.
Cheers,
Adam Nagy
Autodesk Developer Network
Adam Nagy
Autodesk Platform Services
in reply to: adam.nagy
Hi Adam,
i use the GetAt-Methode.
The stupid think is that the error apears when I open the form-designer of one or two forms. All the other forms are OK.
thanks
Regards Jürgen
Is it a TargetInvocationException as I had similar message see http://forums.autodesk.com/t5/NET/WCF-forms-and-TargetInvocationException/m-p/3109376/highlight/true... mistyped WPF in title.
”Boost
