.NET
.net create a polyline with fixed 90 angle
3 REPLIES 3
jackob85
731 Views, 3 Replies
HI i am looking if there is a code in .net to create a polyline that always reshapes itself to keep a 90 degree angle.
That means in case we move the first point of polyline up, down, right or left the second point of polyline move automatically or stretch to keep the 90 degree angle for the polyline.
Because i am trying to make the polyline behave like Visio line when creating a diagram.
I tried a lot of coding and many researches but couldn't find any solution.
So appreciate any help in case there is a solution for this case.
Best Regards, jack
3 REPLIES 3
Hallex
in reply to: jackob85
Hi, Jack
Here is a bad code example but I think
it would be get you started
        	Imports Autodesk.AutoCAD.ApplicationServices
	Imports Autodesk.AutoCAD.DatabaseServices
	Imports Autodesk.AutoCAD.EditorInput
	Imports Autodesk.AutoCAD.Geometry
	Imports Autodesk.AutoCAD.Runtime
	Imports Autodesk.AutoCAD.Colors
        	''named
	Imports acApp = Autodesk.AutoCAD.ApplicationServices.Application
	Imports acGiTm = Autodesk.AutoCAD.GraphicsInterface.TransientManager
	Imports acGiTdm = Autodesk.AutoCAD.GraphicsInterface.TransientDrawingMode
	''_____________________________________________________________________''
        <CommandMethod("dop")> _
        Sub drawOrthoPline()
            Dim db = HostApplicationServices.WorkingDatabase
            Dim doc = acApp.DocumentManager.MdiActiveDocument
            Dim ed = doc.Editor
            Dim pts As Point3dCollection = New Point3dCollection()
            Dim wcs As Matrix3d = ed.CurrentUserCoordinateSystem
            Dim var1 = acApp.GetSystemVariable("ORTHOMODE")
            acApp.SetSystemVariable("ORTHOMODE", 0)
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    tr.TransactionManager.QueueForGraphicsFlush()
                    Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
                    Dim pres As PromptPointResult
                    Dim opts As PromptPointOptions = New PromptPointOptions("")
                    opts.Message = vbLf & "Enter the start point of the line: "
                    pres = ed.GetPoint(opts)
                    Dim p1 As Point3d = pres.Value
                    If pres.Status = PromptStatus.Cancel Then Exit Sub
                    opts.UseBasePoint = True
                    opts.BasePoint = p1
                    opts.UseDashedLine = True
                    opts.Message = vbLf & "Enter the end point of the line: "
                    Dim p2 As Point3d = pres.Value
                    Dim ln1 As Line = New Line()
                    ln1.StartPoint = p1
                    ln1.EndPoint = p2
                    acGiTm.CurrentTransientManager.AddTransient(ln1, acGiTdm.Main, 128, New IntegerCollection())
                    SetUcsBy2Points(p1, p2)
                    pts.Add(p1)
                    pts.Add(p2)
                    doc.SendStringToExecute("<90 ", False, False, True)
                    Dim nucs As Matrix3d = ed.CurrentUserCoordinateSystem
                    opts.BasePoint = p2.TransformBy(nucs.Inverse)
                    opts.Message = vbLf & "Enter the end point of the second line:"
                    Dim p3 As Point3d = pres.Value
                    Dim ln2 As Line = New Line()
                    ln1.StartPoint = p1
                    ln1.EndPoint = p3.TransformBy(nucs)
                    pts.Add(p3.TransformBy(nucs))
                    acGiTm.CurrentTransientManager.AddTransient(ln2, acGiTdm.Main, 128, New IntegerCollection())
                    acGiTm.CurrentTransientManager.EraseTransient(ln1, New IntegerCollection())
                    MsgBox("Write the rest of code to continue to specify the points here")
                    Dim poly As New Polyline
                    Dim i As Integer = 0
                    For i = 0 To pts.Count - 1
                        poly.AddVertexAt(i, New Point2d(pts(i).X, pts(i).Y), 0, 0, 0)
                    Next
                    btr.AppendEntity(poly)
                    tr.AddNewlyCreatedDBObject(poly, True)
                    acGiTm.CurrentTransientManager.EraseTransient(ln2, New IntegerCollection())
                    poly.ColorIndex = 2
                    tr.Commit()
                Catch ex As Exception
                    acApp.ShowAlertDialog(ex.Message & vbLf & ex.StackTrace)
                Finally
                    ed.CurrentUserCoordinateSystem = wcs
                    acApp.SetSystemVariable("ORTHOMODE", var1)
                End Try
            End Using
        End Sub
~'J~
C6309D9E0751D165D0934D0621DFF27919
jackob85
in reply to: Hallex
HI halex,
thanks for the reply,  but my problem is more complexSmiley Sad because i need to keep the polyline reshaping on 90 degree after the polyline is drawn not before and when user move start point or stretch it up or down i need that the second point move automatically to form a 90 degree polyline. because by that user won't need to realign the polyline points  to be othoganal and that will save too much time . and it will be targeted to create a schematic drawings.
Best regards, jack
Hallex
Hi Jack, try another one, though not tested enough,
but I think you need to use custom polyline jig in this case
        Public Function RadiansToDegrees(ByVal radians As Double) As Double
            Return (180 / Math.PI) * radians
        End Function
        <CommandMethod("ord")> _
        Public Sub PickMultiplePoints()
                Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                Dim db As Database = HostApplicationServices.WorkingDatabase
                Dim ed As Editor = doc.Editor
                Dim osm As Int16 = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("osmode")
                Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("osmode", 0)
                Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("orthomode", 0)
            Try
                    Dim btr As BlockTableRecord = TryCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                    Dim n As Integer = 0
                    Dim strang As String = ""
                    Dim ang As Double = 0
                    Dim fstPnt As Point3d = ed.GetPoint(vbLf & "Pick first point: ").Value
                    Dim plan As New Plane(fstPnt, Vector3d.ZAxis)
                    pts.Add(fstPnt)
                    While True
                        Dim ppo As New PromptPointOptions(vbLf & "Pick Next Point (or hit ""Enter"" to Exit): ")
                        ppo.AllowNone = True
                        Dim ppr As PromptPointResult
                        ppo.UseDashedLine = True
                        ppo.UseBasePoint = True
                        ppo.BasePoint = fstPnt
                        ppr = ed.GetPoint(ppo)
                        If (Not (ppr.Status = PromptStatus.OK)) Or (ppr.Status = PromptStatus.None) Then
                            Exit While
                        Dim endPnt As Point3d = ppr.Value
                        pts.Add(endPnt)
                        ed.DrawVector(fstPnt, endPnt, 1, True)
                        If n = 0 Then
                            ang = RadiansToDegrees((fstPnt - endPnt).AngleOnPlane(plan)) + 90
                            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("orthomode", 1)
                            strang = String.Format("<{0} ", ang)
                            doc.SendStringToExecute(strang, False, False, True)
                        Else
                        n += 1
                        fstPnt = endPnt
                    End While
                    Next
                    doc.TransactionManager.FlushGraphics()
                    ed.Regen()
                    tr.Commit()
                End Using
            Catch ex As System.Exception
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbLf & ex.Message & vbLf + ex.StackTrace)
            Finally
                Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("osmode", osm)
            End Try
        End Sub
~'J'~
”Boost
