.NET
Valued Contributor
kcimos
Message 1 of 4 (152 Views)
locking layers in a routine with a new database not working
152 Views, 3 Replies
08-07-2012 01:33 PM
Awhile back I was trying to get some stuff to work & somewhere stumbled upon some code that created a new database object from a filename. I didn't really understand it, but it seemed to work, so fine.
Now I'm trying to add some features to my routine & the following code is not working:
    Shared Function LayerLockDB(ByVal dwgFileName As String, ByVal LayerName As String) As Boolean
        LayerLockDB = False
        Dim acLayerTable As LayerTable
        Dim acLyrTblRec As LayerTableRecord
        Dim myLayerId As ObjectId
        Dim myDb As New Database(False, True)
        myDb.ReadDwgFile(dwgFileName, FileOpenMode.OpenForReadAndAllShare, False, "")
        Using acTrans As Transaction = myDb.TransactionManager.StartTransaction
            Try     ' verify layer exists - If Layer Exist recover LayerID
                acLayerTable = CType(acTrans.GetObject(myDb.LayerTableId, OpenMode.ForRead, True, True), LayerTable)
                myLayerId = acLayerTable.Item(LayerName)
                If myLayerId.IsErased Then          ' If Deleted, Recover Layer
                    acLayerTable.UpgradeOpen()
                    acLayerTable.Item(LayerName).GetObject(OpenMode.ForWrite, True, True).Erase(False)
            Catch ex As Exception               ' Layer Doesn't Exist: Create it
                CreateLayerDB(dwgFileName, LayerName, 7)
                acLayerTable = CType(acTrans.GetObject(myDb.LayerTableId, OpenMode.ForRead, False), LayerTable)     ' Recover LayerID of newly created Layer
            End Try
            acLyrTblRec = acTrans.GetObject(acLayerTable(LayerName), OpenMode.ForWrite)
            acLyrTblRec.IsLocked = True  ' lock layer
            LayerLockDB = True
            acTrans.Commit()
        End Using
        myDb.Dispose()
    End Function
dwgfilename in this case is the name of the current dwg.
I get no erros when running/debugging this, but my layer remains unlocked.
I'm guessing it has to do with the new database object, as if the layer is locked in that database but is not updated in the current dwg.
I guess, fundementally I need to understand what this:
 is trying to do & why it seemed like I needed it in the first place (note my original program (where I thought this worked) opens many drawings & lock a particular layer in them all)
khoa.ho
Message 2 of 4 (135 Views)
Re: locking layers in a routine with a new database not working
08-07-2012 08:58 PM in reply to: kcimos
I see nothing wrong with your code, it's working. However, you forgot to save changes back to database. Just add the code myDb.SaveAs(myDb.Filename, DwgVersion.Current) before myDb.Dispose() and it's good to go.
private static bool LayerLockDB(string dwgFileName, string layerName)
    bool functionReturnValue;
    var myDb = new Database(false, true);
    myDb.ReadDwgFile(dwgFileName, FileOpenMode.OpenForReadAndAllShare, false, "");
    using (Transaction acTrans = myDb.TransactionManager.StartTransaction())
        // verify layer exists - If Layer Exist recover LayerID
        LayerTable acLayerTable;
        try
            acLayerTable = (LayerTable)acTrans.GetObject(myDb.LayerTableId, OpenMode.ForRead, true, true);
            ObjectId myLayerId = acLayerTable[layerName];
            // If Deleted, Recover Layer
            if (myLayerId.IsErased)
                acLayerTable.UpgradeOpen();
                acLayerTable[layerName].GetObject(OpenMode.ForWrite, true, true).Erase(false);
            // Layer Doesn't Exist: Create it
        catch (System.Exception ex)
            CreateLayerDB(dwgFileName, layerName, 7);
            acLayerTable = (LayerTable)acTrans.GetObject(myDb.LayerTableId, OpenMode.ForRead, false);
            // Recover LayerID of newly created Layer
        var acLyrTblRec = (LayerTableRecord)acTrans.GetObject(acLayerTable[layerName], OpenMode.ForWrite);
        acLyrTblRec.IsLocked = true;
        // lock layer
        functionReturnValue = true;
        acTrans.Commit();
    // Update the current database with the new locked layer
    myDb.SaveAs(myDb.Filename, DwgVersion.Current);
    myDb.Dispose();
    return functionReturnValue;
-Khoa
Valued Contributor
kcimos
Message 3 of 4 (128 Views)
08-07-2012 09:39 PM in reply to: kcimos
Thanks. That seems like the exact sort of thing that it was missing.
khoa.ho
Message 4 of 4 (104 Views)
08-08-2012 06:52 AM in reply to: kcimos
You are welcome. Glad to see it works.
-Khoa
You are not logged in.
Announcements
Need installation help?
Ask the Community
