.NET
loading .net modules.
1 REPLY 1
StormyC
367 Views, 1 Reply
Hey all
I have a plugin that loads up other dlls using the "System.Reflection.Assembly.LoadFrom($Dllname)" method.
This works very well, however, the plugin only runs and loads the dlls in the first session of AutoCAD...
Can this be made to run in all open sessions of AutoCAD.
Win7 Pro 64bit
AutoCAD 2014
1 REPLY 1
StormyC
in reply to: StormyC
As my plugin tries to copy newer .dlls before loading them the plugin was crashing out, without visible errors, due to the dlls being "already in use".
Solved problem by disabling my dll copy if more than one AutoCAD session is loaded.
”Boost
