• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor
    list dot paired to form
    112 Views, 6 Replies
    04-18-2012 07:45 AM
    I try to make a form with à list dot paired:
    (("mscorlib.dll" . "2.0.0.0") ("AcdbMgd.dll" . "18.0.0.0"))
    A simple form with 2 column and a windows not fix, expandable !
    My problem how to transfert list to .net (VB) ?
    Daniel OLIVES
    (Sorry for my poor english a french user !)
    Please use plain text.
    *Expert Elite*
    Re : list dot paired to form
    04-18-2012 08:33 AM in reply to: dolives
    Salut,
    Comment to code obtient-il cette liste, depuis un LISP ?
    How do your code get this list, from a LISP ?
    Gilles Chanteau
    *Expert Elite*
    Hallex
    Re: list dot paired to form
    04-18-2012 08:36 AM in reply to: dolives
    Have you tried Dictionary(of string,string) or something else
    Try this out
      Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                Dim ed As Editor = doc.Editor
                Dim dict As Dictionary(Of String, String) = New Dictionary(Of String, String)
                dict.Add("mscorlib.dll", "2.0.0.0")
                dict.Add("AcdbMgd.dll", "18.0.0.0")
                For Each key As String In dict.Keys
                    ed.WriteMessage(vbLf + "{0}" + vbTab + "{1}", key, dict(key))
                Next
    ~'J'~
    _____________________________________
    C6309D9E0751D165D0934D0621DFF27919
    *Expert Elite*
    arcticad
    04-18-2012 08:50 AM in reply to: Hallex
    http://www.dotnetperls.com/keyvaluepair-vbnet
    “We don’t have a snowball’s chance in a blast furnace of surviving this attack unless every one of our units gets into the fight right now!”
    04-19-2012 09:19 AM in reply to: dolives
    Thank you very much !
    Daniel OLIVES
    04-19-2012 09:24 AM in reply to: _gile
    Hi Gile,
    Yes the list is create form lisp code, i try to just put it in a form i, dot net !
    daniel OLIVES
    *Expert Elite*
    04-19-2012 11:39 AM in reply to: dolives
    If I don't misunderstand, you build a LispFunction which an argument is dotted pair list, for example:
    (foo '(("mscorlib.dll" . "2.0.0.0") ("AcdbMgd.dll" . "18.0.0.0")))
    Your NET code will get the argument as a ResultBuffer (a collection of TypedValues). For the upper example the ResultBuffer will contain these TypedValues where the first item (TypeCode) is a value of the LispDataType enum.
    For example, this LispFunction Method:
            [LispFunction("foo")]
            public TypedValue foo(ResultBuffer resbuf)
                Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
                if (resbuf == null)
                    return new TypedValue((short)LispDataType.Nil);
                else
                    foreach (TypedValue tv in resbuf)
                        ed.WriteMessage("{0} : {1}\n", tv.TypeCode, tv.Value);
                    return new TypedValue((short)LispDataType.T_atom);
    with (foo '(("mscorlib.dll" . "2.0.0.0") ("AcdbMgd.dll" . "18.0.0.0"))) will write on command line:
    5016 : -1
    5016 : -1
    5005 : mscorlib.dll
    5005 : 2.0.0.0
    5018 : -1
    5016 : -1
    5005 : AcdbMgd.dll
    5005 : 18.0.0.0
    5018 : -1
    5017 : -1
    5016 => LispDataType.ListBegin
    5005 => LispDataType.Text
    5018 => LispDataType.DottedPair
    5017 => LispDataTypeListEnd
    Care, if your dotted pairs have a key/value corresponding to valid TypedValues (DxfCode and a corresponding value) it will be seen by .NET as a single TypedValue.
    (foo '((0 . "INSERT") (10 0.0 0.0 0.0) (66 . 1)))
    will print:
    5016 : -1
    0 : INSERT
    10 : (0,0,0)
    66 : 1
    5017 : -1
    I expect it helps. Feel free to post on a French speaking forum we both de more comfortable.
    Gilles Chanteau
