• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    linking dwg to external database
    201 Views, 1 Replies
    05-10-2012 10:20 PM
    Hi
    How can I link an external database(say access/oracle) to a drawing so that I m able to insert/update attribute directly from the autocad map drawing.
    Murali
    Please use plain text.
    Re: linking dwg to external database
    05-12-2012 02:57 AM in reply to: murali.pandey
    That could be done using the command _DBCONNECT (>>>details<<<)
    Using Map3D you can also use the command _MAPCONNECT (check >>>here<<<) to connect to a database.
    That is what I don't understand! What records do you have in your database and how are they set in relation to AutoCAD-objects? Who or what creates the relation between AutoCAD-blocks/attribtues to the database? When should you AutoCAD-BlockAttributes be updated? .... So please describe a little bit more detailed what you like to get and - as this is a development forum - what code makes you troubles.
    If you have troubles just to connect to a database from dotNET then you can search the www for OLEDB and you will get millions of sample codelines.
    - alfred -
    Alfred NESWADBA
